Medion Akoya T80 SFF MD35422 Windows 11 Install problem
3 ANTWORTEN 3
gimmacks
Nachricht 1 von 4
2.174 Aufrufe
Nachricht 1 von 4
2.174 Aufrufe
Hello
I have just bought a Medion Akoya T80 SFF MD35422. I'm trying to install windows 11 but it says that I have to install Driver to show hardware. I have downloaded the drivers pack from the support page (drv_t80_m12_w1x.zip) but I cannot find the right driver.
which must I use to install windows 11?
Thank you very much for your help.
Best regards.
gimmacks
Nachricht 4 von 4
2.111 Aufrufe
Nachricht 4 von 4
2.111 Aufrufe
Hello
Problem solved.
The solution was creating de usb install tool in and old pendrive and plug it in the usb 2.0 port in the back (black ones) of the computer.
Best regards.
3 ANTWORTEN 3
Nachricht 2 von 4
2.167 Aufrufe
Nachricht 2 von 4
2.167 Aufrufe
@gimmacks
I guess it is  Intels RST driver, or the isolated VDM driver, to enable the bios to initiate the PCIe disk. Probably you have to put a link to  the driver; you can put them on the Win11 USB Installation stick, if you do use one,  or a single empty USB stick, which has to be inserted in an USB port before you switch the PC on.
Success, daddle
gimmacks
Nachricht 3 von 4
2.164 Aufrufe
Nachricht 3 von 4
2.164 Aufrufe
Hello
Thank you very much for your quick answer.
Where can I get this driver? Is not in the driver package I downloaded from medion support site?
Best regards.
gimmacks
Nachricht 4 von 4
2.112 Aufrufe
Nachricht 4 von 4
2.112 Aufrufe
Hello
Problem solved.
Best regards.
3 ANTWORTEN 3
