Medion Akoya P66089 upgrade capabilities
2 ANTWORTEN 2
mexax
Nachricht 1 von 3
4.243 Aufrufe
Nachricht 1 von 3
4.243 Aufrufe
Hi, I have the Medion Akoya P66089/ MSN 1002 3644 and wanted to ask about its upgrade capabilities, rather if I can replace the PSU with another one from corsair, be quiet or others without any problems. Or if there are going to be some issues. (Space, mainboard compatibility, etc)
Why do I want to upgrade the PSU? 'Cause I wanted to upgrade the GPU to something better than the 1650, a 3060 for example.
Or should I just heads up buy a completely new pc?
Thanks in advance!
Mastermind
Nachricht 2 von 3
4.236 Aufrufe
Nachricht 2 von 3
4.236 Aufrufe
Hi @mexax ,
you´re owning a MEDION AKOYA P66089 MD 34270 which was distributed in 2020 and checking the specs this should still be a suitable PC for doing office work, handling your e-mails and surfing the internet.
For many operations the 512 GB PCIe M.2 SSD is as suitable as the Intel 10thGen I5 CPU and 8GB RAM can be extended (if necessary) up to a max. 32 GB by using the full capacity of both RAM slots.
The chraracteristics of the PSUP can be found here, so you can check for a more powerful one.
Cheers
2 ANTWORTEN 2
Mastermind
Nachricht 2 von 3
4.237 Aufrufe
Nachricht 2 von 3
4.237 Aufrufe
Hi @mexax ,
Cheers
mexax
Nachricht 3 von 3
4.225 Aufrufe
Nachricht 3 von 3
4.225 Aufrufe
I see. Thank you!
2 ANTWORTEN 2
