Medion AKYOA P67075 RAM upgrade
13 ANTWOORDEN 13
patD
Bericht 1 van 14
5.003 Weergaven
Bericht 1 van 14
5.003 Weergaven
Hello,
I have a Medion AKYOA P67075 (MSN 10023704) and I wanted to upgrade the memory from the original 2 x 8GB RAM to 2 x 16 GB RAM but after installing the new RAM my computer emits 3 beeps when restarting so I guess the new memory is incompatible.
Here is the info of the original memory
Samsung M378A1G44AB0-CWE 8GB DDR4 3200MHz PC4-25600 1.2V 1Rx16 288 Pin UDIMM PC4-25600 1.2V 1 Rx1 Desktop RAM Memory Module
Here is the info of the new memory (photo attached):
SK Hynix HMA82GR7DJR8N - 16GB 2Rx8 PC4 32000MHz
Have I bought the wrong memory? Any suggestion would be very welcome.
Many thanks,
Patrick
13 ANTWOORDEN 13
Bericht 11 van 14
1.427 Weergaven
Bericht 11 van 14
1.427 Weergaven
Hello @patD
apparently the information in the database is incorrect.
According to it, only 2666 MHz is possible with the B460H6-EM board.
However, your image, which has now been released, suggests otherwise.
This should be checked.
bye Fishtown
patD
Bericht 12 van 14
1.402 Weergaven
Bericht 12 van 14
1.402 Weergaven
Hello Fishtown,
I have checked Task Manager > Performance > Memory and the Speed reads 2667 MHz which fits with the motherboard information.
I guess the following memory should work (photo attached).
Samsung 16gb (16GB x 2) 32gb total DDR4 PC4-2666V M378A2K43 PC RAM
Many thanks for your help.
Patrick
Bericht 13 van 14
1.383 Weergaven
Bericht 13 van 14
1.383 Weergaven
Hi @patD
there is nothing against it: https://geizhals.de/samsung-dimm-16gb-m378a2k43cb1-ctd-a1779434.html
bye Fishtown
Bericht 14 van 14
4.434 Weergaven
Bericht 14 van 14
4.434 Weergaven
@patD
@Fishtown  schrieb:
the RAM supports up to 3200 MHz, but the motherboard doesn't:
Please check your computer's specifications under "Motherboard (MB ECS B460H6-EM)" in your link.
There, under "Memory Support," it states: maximum DDR4 2666 MHz.
There is some misunderstanding in the above statement.
You can put  DDR4 RAM with the speed 3200 MHz in, but the board only utilizes a lower speed.
As I wrote  already in my former post
That's what your original RAM also proves.
This picture  is not proving anything, except your 3200 MHz RAM offers the mentioned Jedec speeds up  to 1600 MHz. Also lower Jedec speeds, which means round about 1300 MHz to suite your chipset and mainboard. To see the actual speed you have to check the memory page.
An I do suppose you knew that page, which gives the correct speed your board utilizes. But seeing the possible sped in the Jedec listing you got a bit greedy. But read my post 8 again.
And be aware because  it is a DDR (Double Data Rate), RAM,  the working speed therefore is doubled.
Also my B460 board works with a 3200 MHz RAM, at 2600 MHz ( Jedec ~1300) maximum speed.
Below in this statement the same error, CPU-Z shows on your CPU-Z page  the Jedec specifications. To see the actual  ram speed check on page memory:
@Fishtown  schrieb:
However, you should check the "SPD" tab under "Displayed Frequency"; this corresponds to the actual clock speed at the time of measurement.
This OEM motherboard supports a maximum of 2666 MHz
 Yes, it drives the built in3200 MHz RAM, but  at 2600 MHz only.
Bye, daddle
13 ANTWOORDEN 13
