I'd like to put a GPU in my E63003
2 REPLIES 2
BobSwinger69
Message 1 of 3
Message 1 of 3
Hi, I'd like to put a GPU in my E63003 but taking off the cover and looking inside there does not seem to be much room. Has anyone tried this who could suggest a GPU which would fit? I'd like to use the GPU to render in Blender.
Many Thanks
Tags (3)
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @BobSwinger69 ,
do you have the MSN number of your unit?
Regards,
Gehringer
Mastermind
Message 3 of 3
Message 3 of 3
Hi @BobSwinger69 ,
if you can confirm, that the machine you own is the MEDION AKOYA E63003 MD 34255 ( 10023412), I can inform you thatg you can upgrade your system with a dedicated graphics card on the PCIe x16 socket.
Pls inform us, if you need further assistance.
Cheers
2 REPLIES 2
