How to I get into bios? Medion Erazer P10?
28 REPLIES 28
haahu
Message 1 of 29
Message 1 of 29
Hi. I tried to get into bios for days now?
1. Does anyone know which key triggers the bios start-up?
2. When I try to enter bios via Windows, through settings, the pc restarts and stops, screen black.
I'm getting pretty desperate here, tbh.
1 ACCEPTED SOLUTION
Message 28 of 29
Message 28 of 29
Hello @haahu
what I can think of just now:
if your assumption is correct, then if you have come into the bios with the Del key you should have a black screen
because the bios accesses the non-existent graphics onboard.
Then when you press ESC(Exit) or F10 (save and exit) afterwards Windows start up.
(ESC or F10 = the bios would be closed and the operating system would be loaded)
that would confirm your acceptance.
bye Fishtown
28 REPLIES 28
Gehringer
Retired
Message 2 of 29
Message 2 of 29
Hi @haahu ,
F2 must do the trick.
Regards,
Gehringer
haahu
Message 3 of 29
Message 3 of 29
Hi,
I did try F2, but the screen goes blank.
But this is confirmation F2 is the correct key.
It seems the bios fails to show or the screen fails to display it. Same happens when I force restart to bios via Windows settings.
My grfxcard and screen are otherwise working 100%.
I find this odd, as it's a brand new pc.
Gehringer
Retired
Message 4 of 29
Message 4 of 29
Hi @haahu ,
have you tried to reset your unit to its factory settings?
Just be aware that this procedure will erase all your data, therefore you should back it up previously and make sure you can recover all the apps/software and the credentials to access them.
Regards,
Gehringer
haahu
Message 5 of 29
Message 5 of 29
No. Didn't work. Called Medion. They said F11, but didn't work either.
haahu
Message 6 of 29
Message 6 of 29
Does anyone know what brand of motherboard this model uses?
MEDION ERAZER ENGINEER P10
Message 7 of 29
Message 7 of 29
Hi @haahu and welkome
Please give your MSN number. there were different Moatherboards that were installed
Board ECS B560H6-EM:
Executing the UEFI firmware configurationYou can only run the configuration program upon system startup. If the PC has already been started, shut down Windows® and restart it.Before the PC reboots, press the Del key and hold it down until the message Entering Setup appears.
Board ECS B460H6-EM:
The same
bye Fishtown
haahu
Message 8 of 29
Message 8 of 29
MSN? I have a SN: MV7110G11200742. Also a 20068998 on the same sticker
Another sticker reads "MV7110 00
EA = 1C697A7EC2AB"
haahu
Message 9 of 29
Message 9 of 29
Found my MSN 20068317
What MB is this?
haahu
Message 10 of 29
Message 10 of 29
Also: MD35024
28 REPLIES 28
