Handbuch?
6 ANTWORTEN 6
Davder159
Nachricht 1 von 7
11.629 Aufrufe
Nachricht 1 von 7
11.629 Aufrufe
Handbuch?
Hey,
Wo finde ich das handbuch/ technische Daten vom H81H3-EM2 mainboard? Im Web gibts irgendwie nichts?
Nachricht 4 von 7
11.607 Aufrufe
Nachricht 4 von 7
11.607 Aufrufe
Moin @Davder159
Technische Daten:
MB ECS H81H3-EM2 C2 Step
MSN:20058531
Hauptmerkmal:CPU-Socket: Intel LGA 1150
Chipset: Intel DH82H81 SR177 C2 Step
Technische Kerndaten: ECS H81H3-EM2 v1.0
* FSB: 1333MHz / 1600MHz / 1866MHz
* RAM: max. 16 GB (2 Slots)
* Form Factor: Micro-ATX (8 mounting holes)
Processor Support
  • Processor in the LGA1150 package
  • Supports 4 pin CPU Fan Pin-Header with Fan Speed Control
Chipset
  • Intel DH82H81 SR177 C2 Step
Memory Support
  • DDRIII-1333/-1600/-1866 (max. 16GB)
  • 2 DDRIII DIMMs (240pin / 1.5V)
  • Single / Dual channel mode
Network
  • LAN: 10/100/1000 by Realtek RTL8111GN
  • WLAN: ./.
  • IEEE1394: ./.
Audio
  • 6 channels audio codec Realtek ALC662-VD HDA
IDE / Serial ATA / Floppy
  • Floppy: ./.
  • IDE: ./.
  • Serial ATA:
    • SATA ports (2x grey color = SATA III / 1x orange color = SATA II / 1x black color = ESATA II)
BIOS
  • AMI EFI BIOS APTIO core (new EFI)
  • SPI flash (64Mbit)
Connectors
  • Back panel:
    • 4 USB 2.0 ports
    • 1 LAN (RJ-45) jack
    • 1 HDMI output
    • 1 VGA output
    • 1 DP output
    • Audio Jacks:
    ° 1 x Front line out (green)
    ° 1 x Line in (blue)
    ° 1 x Mic in (pink)
  • On-Board Pinheaders:
    • 2 x SATA III ports (2x grey color = SATA III)
    • 1 x SATA II port (1x orange color)
    • 1 x internal eSATA (1x black color = SATA II)
    • 1 x CPU 4PIN Fan header ⿝CPU_FAN⿝
    • 1 x Sys FAN 4PIN ⿝SYS_FAN1⿝
    • 1 x Front Audio ⿿F_AUDIO⿝
    • 1 x Frontside USB :⿿F_USB1⿝ with ⿿white⿝ plastic header (two port)
    • 1 x Frontside USB :⿿F_USB2⿝ with ⿿white⿝ plastic header (one port)
    • 1 x Front_Panel header ⿿F_PANEL⿝
    • 1 x 4PIN ATX 12V connector ⿿ATX_12V⿝
    • 1 x 14PIN ATX connector ⿿ATX_POWER⿝ only for single power out PSU
    • 1 x 4 PIN HDD power ⿿HDD_PWR⿝
    • 1 x 4 PIN ODD power ⿿ODD_PWR⿝
    • 1 x SPI ⿿SPI_DEBUG1⿝
    • 1 x LPC_DEBUG
    • 2 x internal USB3.0 ports Typ A (blue)
Slots
  • 1 PCIe x16
  • 3 PCIe x1
Abmessungen / Gewicht
  • Form Factor: Micro-ATX
6 ANTWORTEN 6
Iks-Jott
Nachricht 2 von 7
11.625 Aufrufe
Nachricht 2 von 7
11.625 Aufrufe
@Davder159
Passt das?
Sonst bitte hier  selbst suchen.
Iks-Jott
Davder159
Nachricht 3 von 7
11.619 Aufrufe
Nachricht 3 von 7
11.619 Aufrufe
Nein leider das falsche. Wird nichts mit selbst suchen es gibt einfach nichts wo ich sehen kann welche Sachen kompatibel sind usw..
Recht schade, auf der Herstellerseite auch nicht zu finden...
Nachricht 4 von 7
11.608 Aufrufe
Nachricht 4 von 7
11.608 Aufrufe
Moin @Davder159
Technische Daten:
MSN:20058531
Processor Support
Chipset
Memory Support
Network
  • WLAN: ./.
  • IEEE1394: ./.
Audio
  • Floppy: ./.
  • IDE: ./.
  • Serial ATA:
BIOS
Connectors
  • Back panel:
    • 4 USB 2.0 ports
    • 1 HDMI output
    • 1 VGA output
    • 1 DP output
    • Audio Jacks:
    ° 1 x Mic in (pink)
    • 1 x LPC_DEBUG
Slots
  • 1 PCIe x16
  • 3 PCIe x1
Davder159
Nachricht 5 von 7
11.602 Aufrufe
Nachricht 5 von 7
11.602 Aufrufe
Danke dir war hilfreich, meinst du aus dem alten pc kann man noch gsming Leistung kriegen?
Nachricht 6 von 7
11.597 Aufrufe
Nachricht 6 von 7
11.597 Aufrufe
Moin @Davder159
Nenn bitte noch deine MSN Nummer um zu sehen was verbaut ist und was möchtest du noch aufrüsten!
Im anderen Beitrag schreibst du ja "Mit aufrüsten meine ich halt eigentlich so alles bis auf mainboard (CPU,gpu,Netzteil,Gehäuse,..)"
Bleibt nicht viel über oder! 😉
Davder159
Nachricht 7 von 7
11.591 Aufrufe
Nachricht 7 von 7
11.591 Aufrufe
Ich schreibe dies hier zum 3 mal weil ich immer die Seite aktualisiere ._. Kurzgefasst.
Msn:10019462
Grafikkarte soll rein (1050ti??) Evtl.
CPU (i5 i7 sowas?)
Gehäuse
Netzteil (400w?)
Einfach nur danke, ♡ haha
6 ANTWORTEN 6
