H110H4-EM2 black screen and 5 beeps while start
2 REPLIES 2
LoganJ
Message 1 of 3
Message 1 of 3
Hello. I have bought a 3 motherboard H110H4-EM2 v1.0
When i try to start any of there i have this symptoms
5 short beeps and black screen.
If i short pwr_sw the mother board will shutdown.
My configuration:
-H110H4-EM2 v1.0 14pin
-CPU Pentium G4560 or Celeron G3900(was try on both)
- DDR4 4gb
- Power supply is connecterd using 24 pin to 14 pin  adapter  and i try using 14pin FSP Power SUpply
Maybe anyone have same problem and know what is the main reason of problem?
Tags (1)
2 REPLIES 2
RAZZ
Message 2 of 3
Message 2 of 3
Hi @LoganJ ,
normally when you get 5 beeps on start up this will indicate that there is an issue with the processor,
Try to see id you can verify the processor is connected correctly (no bent pins on the motherboard socket)
thanks
LoganJ
Message 3 of 3
Message 3 of 3
Is any list of CPU support for this mother board exist?
2 REPLIES 2
