Eraser i5 10400 3060TI RAM upgrade?
10 RÉPONSES 10
MarcNSmith
Message 1 sur 11
4 935 Visites
Message 1 sur 11
4 935 Visites
Sorry  Erazer i5 10400 3060TI
Tried twice to upgrade RAM, first issue was restricted space due to CPU fan and second issue was Crucial DDR4 pro 32GB 3200 doesn't work. Does anyone have a suggestion of what actually will work please?
This was bought from Aldi in Nov 2021.
B560 motherboard with two RAM slots.
1 SOLUTION APPROUVÉE
Solutions acceptées
MarcNSmith
Message 10 sur 11
3 198 Visites
Message 10 sur 11
3 198 Visites
Very good, thanks
I have now researched this and I just hope the motherboard is compatible with 11th Gen processors as B460 is not and this is a B560???
10 RÉPONSES 10
Message 2 sur 11
4 530 Visites
Message 2 sur 11
4 530 Visites
@MarcNSmith
Hi. Nobody  can help you if you do not specify first the Medion PC with name and MSN number, and second the RAM modul more exactly. Providing a link to the retailer selling the Crucial RAM would be helpful too.
Cheers, daddle
MarcNSmith
Message 3 sur 11
4 507 Visites
Message 3 sur 11
4 507 Visites
System MD 34625
B560 H6-EM2
RAM crucial pro  CP18g4dfra33a. 16gb DDR4 3200
Is there any RAM that will work for 2x16GB and at 3200?
Message 4 sur 11
4 502 Visites
Message 4 sur 11
4 502 Visites
@MarcNSmith
@MarcNSmith  schrieb:
System MD 34625
B560 H6-EM2
You can not use in this mainboard XMP memory modules. They will fall back  at 2400 MHz.
Check on the modules which came with the system for their  specs. They should have a sticker or imprint telling you. But you can not enhance the  speed you would like to.
Because there is an IT dropdown on the Medion database, I can not tell you exactly about the built in RAM. But you could try 2x 16 GB modules,
Special: We do not give tips for any brand.
Cheers, daddle
MarcNSmith
Message 5 sur 11
4 365 Visites
Message 5 sur 11
4 365 Visites
I found some 32GB RAM that works
Crucial CP2K 18G4 DFRA 32A
2 x 16 GB
Chips are single side
MarcNSmith
Message 6 sur 11
3 266 Visites
Message 6 sur 11
3 266 Visites
A further question I am looking to upgrade to a 5060TI from the 3060TI in the near future but not sure the processor i5 10400 will cope?
What faster processors can I put on to the motherboard, can it only be the i7 10700?
System MD 34625
B560 H6-EM2
Thanks,
Marc
Message 7 sur 11
3 250 Visites
Message 7 sur 11
3 250 Visites
@MarcNSmith
Why shouldn't it not work? Or are there special notes from Nvidia which restricts the use of the 5060 TI to special conditions? But this you should ask with  or in the Nvidia forum.
Check here about the details of your MB:
--> https://community.medion.com/t5/FAQs/FAQs-about-the-ECS-B560H6-EM2-mainboard/ta-p/153958
Bye, daddle
MarcNSmith
Message 8 sur 11
3 244 Visites
Message 8 sur 11
3 244 Visites
After the GPU I am looking at a faster processor and do not know what the motherboard can take as I don't understand
FAQs about the ECS B560H6-EM2 mainboard
  • Comet-Lake-S / Rocket-Lake-S
  • Sockel 1200
Message 9 sur 11
3 231 Visites
Message 9 sur 11
3 231 Visites
@MarcNSmith
That says you can use any
  • Comet-Lake-S / Rocket-Lake-S  Proc  which utílizes the Socket 1200.
MarcNSmith
Message 10 sur 11
3 199 Visites
Message 10 sur 11
3 199 Visites
Very good, thanks
10 RÉPONSES 10
