ECS H81H3-TI
17 ANTWORTEN 17
macminn
Nachricht 1 von 18
23.676 Aufrufe
Nachricht 1 von 18
23.676 Aufrufe
ECS H81H3-TI
Hi all
I just purchased this board which I understand was once part of a Medion AIO PC, having trouble finding support, hope I've come to the right place!
Cheers
Chris
Luke
Community Manager
Nachricht 10 von 18
16.645 Aufrufe
Nachricht 10 von 18
16.645 Aufrufe
Hi @macminn,
we finally found the relevant unit:
MEDION AKOYA P2021 D AIO EU
MSN: 10018813
Vertriebsland: EU
Hauptmerkmal: All-in-One PC 23,6"
PC System 8940 EU (MB ECS H81H3-TI) AIO9
Now go to our website https://www.medion.com/de/service/start/_product.php
and fill in the MSN 10018813, then click on "Treiber". That`s it.
*Uff*   🙂
Luke
17 ANTWORTEN 17
Luke
Community Manager
Nachricht 2 von 18
16.368 Aufrufe
Nachricht 2 von 18
16.368 Aufrufe
Hi @macminn,
We know that this board has been used in certain AIO-PCs, but we need the specific MSN number of this unit which should be printed on a label located on the back of the board...   so please have a look and/or take a photo of the label. The more info, the better...
Cheers,
Luke
macminn
Nachricht 3 von 18
16.362 Aufrufe
Nachricht 3 von 18
16.362 Aufrufe
Thanks Luke! No labels on back but a couple on front...please see attached.
Luke
Community Manager
Nachricht 4 von 18
16.359 Aufrufe
Nachricht 4 von 18
16.359 Aufrufe
Hi @macminn,
I´m afraid that won`t do as none of these labels are related to a MEDION AIO-PC or any other
of our hardware.
Plan B:
I´ve played around with googling for your board`s type designation  and found several useful links which I can`t
publish here for obvious reasons.
Hope this helps,
Luke
macminn
Nachricht 5 von 18
16.352 Aufrufe
Nachricht 5 von 18
16.352 Aufrufe
I bought the board on ebay, vendor included these images. One says it's from a Medion P2005DR, other seems to have an MSN of 20055556.
I think this sticker is missing on mine (the vendor was selling several), but my  board is the same. Description said "new boards removed from barebones systems".
But when I search on these I don't find any results.
Interested in latest BIOS and drivers. I do see on this site there is an updated BIOS for meltdown and spectre in the testing phase, would like an eta if possible.s-l1600-2.jpgs-l1600.jpg
macminn
Nachricht 6 von 18
16.347 Aufrufe
Nachricht 6 von 18
16.347 Aufrufe
I've also just realized there are numbers on the shield. EX5070 and 20055555.
Luke
Community Manager
Nachricht 7 von 18
16.342 Aufrufe
Nachricht 7 von 18
16.342 Aufrufe
Hi @macminn,
These number are used by ECS only and not related to the AIO PC, sorry...
However, I did an internal database search for "ECS" and only found this one:
MEDION AKOYA P2004 AIO UK
MSN: 10017988
Vertriebsland: GB
Hauptmerkmal: All-in-One PC 23,0"
PC System 8647.3 UK (MB ECS H61H2-TI2) AIO7
Prozessor:  CPU Intel Core i3-3220 3,30GHz
Hauptspeicher:  2x 2048 MB DDR3 SO-DIMM
(PC3-12800/1600 MHz) 8 GB max.
BIOS/Chipsatz:  H61TIW08.1xx (BIOS)
Intel BD82H61 SLJ4B B3 step
Display:  23,0" (58,4 cm) TFT Widescreen-Display
Auflösung: 1920 x 1080 Pixel (16:9) Glare
Grafikkarte:  Intel® HD 2500 Grafik
(onBoard)
* Codename: Ivy Bridge
* Pipelines: 16 - unified
* Kerntakt : 650 - 1050 MHz
* Shadertakt : 650 - 1050 MHz
* Shared Memory: ja
* DirectX: 11, Shader 5.0
* Herstellungsprozess: 22 nm
* Features: QuickSync
Soundkarte:  Realtek ALC662 HDA 6 Channel Codec
Akku:  Lithium-Ionen-Akkumulator: n/a
AC - DC Power Supply, 150 W (MSN 40040599)
In: U~ = 100-240 V (50/60 Hz)
Out: U_ = 19.5 V; 7.7A
w/o I/O switch
Optisches Laufwerk:  DVDRW SAM SN-208BB
Festplatte:
Netzwerk:
Software:
Komponenten:
It`s not exactly the same board, but the closest I can get.
Drivers can be downloaded from our german website:
https://www.medion.com/de/service/start/_product.php?msn=10017859&gid=00
...just click on "Treiber" (Driver) and download & try the drivers offered there. I can`t assure this will work 100%, but it is the best I´ve found.
Cheers,
Luke
Luke
Community Manager
Nachricht 8 von 18
16.334 Aufrufe
Nachricht 8 von 18
16.334 Aufrufe
Addendum:
As this is an official ECS board, I also did a direct search on their website...  this one is the closest you`ll ever get:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Overview.aspx?DetailID=1713&CategoryID=1&MenuID=172...
Luke
macminn
Nachricht 9 von 18
16.320 Aufrufe
Nachricht 9 von 18
16.320 Aufrufe
Well, I do appreciate you effort Luke. Obviously information on the H81H3-TI2 or H61H2-TI2 is not likely to be very useful. While it's possible that there may be some drivers in common with the H81H3-TI2 I certainly would not want to try a bios for a different board.
It seems odd to me that even though I have been able to find some evidence that this board is used in a Medion AIO machine, there is little or no support information to be found using any of the available tools.
So, I will continue to watch for the bios update for this board which I found on this site. And I think I have found somene on another site who actually owns one of these machines and may be able to help me.
Thanks
Luke
Community Manager
Nachricht 10 von 18
16.646 Aufrufe
Nachricht 10 von 18
16.646 Aufrufe
Hi @macminn,
MSN: 10018813
Vertriebsland: EU
*Uff*   🙂
Luke
17 ANTWORTEN 17
