op 11.05.2021 08:44
op 11.05.2021 08:44
Hi all,
I have a Medion P5370 E (MD8866) which was sold here in Australia at Aldi as the gaming computer.
I have just had an issue arise where on start-up the computer will power on with a black screen, the Medion logo will then display, and usually there is the blue spinning wheel below it showing that windows is loading, however that is not appearing. And it stays on that screen.
I had a technician check basically everything, from bios settings, motherboard function, GPU, tried swapping out the SSD with a new one and doing a fresh Windows install - nothing is working.
Does anyone have any suggestions? Is it possible the UEFI bios has somehow been corrupted and needs to be flashed?
Im tearing my hair out.
op 13.05.2021 12:54
op 13.05.2021 12:54
First I changed the bios to not be a secure boot, which got me past the hanging logo screen to a blue screen that a driver was missing- wdfilter.sys.
I created a recovery drive on USB and attempted the auto repair, but that didn't work. So I downloaded a fresh wdfilter.sys file, and used the recovery drive to enter command prompt where I copied the file into the relevant folder.
Restarted and it booted with no issues.
op 12.05.2021 08:57
op 12.05.2021 08:57
Hi @WinstonH ,
it is hard to tell you the fault without knowing exactly what has been been done to the unit.
If there has been an attempt to flash or update/modify the BIOS, then it is possible that it's corrupted.
But the type of fault you are experiencing can have many causes: unsuccessful Windows update, corrupted booting instructions, faulty disc, etc.
If you have already had a technician seeing the unit, I would advise you to get in touch with your local Medion technical support team and check what are the possibilities for your case.
Regards,
Gehringer
op 13.05.2021 10:08
op 13.05.2021 10:08
Thanks for your reply. I ended up solving the issue myself.
op 13.05.2021 11:42
op 13.05.2021 12:54
op 13.05.2021 12:54
op 13.05.2021 14:04
op 13.05.2021 14:06
op 13.05.2021 14:06
The blue screen gave me the full path location for the missing driver.
