BIOS 110EMW0X.105 Please
16 ANTWOORDEN 16
pepeludo
Bericht 1 van 17
22.597 Weergaven
Bericht 1 van 17
22.597 Weergaven
Hello everyone,
Sorry about my English. I'm trying to download the Bios version 110EMW0X.105 to update my version (110EMW0X.102)  from here but the link is dead.
Can someone send me this Bios?
Thank you very much.
Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz, 2712 Mhz
BIOS American Megatrends Inc. 110EMW0X.102, 04/03/2016
16 ANTWOORDEN 16
unwindingthree8
Bericht 11 van 17
7.020 Weergaven
Bericht 11 van 17
7.020 Weergaven
Electrically there is no difference between skylake and kabylake. It's the microcode in the bios that enables forward compatibilty. The tinkerer in me wants to flash a rev 2 bios onto the other board lol
Mastermind
Bericht 12 van 17
6.989 Weergaven
Bericht 12 van 17
6.989 Weergaven
Hi @Baba ,
absolutely,you´re right with that.
@Baba  schrieb:
A question for @Major_ToM :  So is version 2 of the motherboard considered the same as revision 2?
Thank you.
Cheers
victor_rua
Bericht 13 van 17
5.763 Weergaven
Bericht 13 van 17
5.763 Weergaven
Hello, I am trying to update my bios but links are fallen, where can i get a 110emw0x. 208 or later update link pls?
Tags (2)
Bericht 14 van 17
5.756 Weergaven
Bericht 14 van 17
5.756 Weergaven
Hi @victor_rua and welcome
https://www.medion.com/en/servicebackend/_lightbox/software_details.php?did=17738
bye Fishtown
thisistheone
Bericht 15 van 17
5.661 Weergaven
Bericht 15 van 17
5.661 Weergaven
Hello, thanks for the BIOS links. I have two question if you please.
1) How do I check exactly which version of the H110H4-EM motherboard I have? In my tool CPU-Z it reports that I have:
Motherboard
  Manufacturer: MEDION
  Model: H110H4-EM           2.0
  Chipset: Intel    Skylake    Rev. 07
I'm pretty sure this means I have H110H4-EM v2.0, but how can I check for sure, do I inspect the motherboard, the BIOS, where do I go?
2) According to FAQs here https://community.medion.com/t5/FAQs/FAQs-about-the-ECS-H110H4-EM-mainboard/ta-p/153046  the maximum upgrade CPU for this motherboard
CPUs of the Skylake 6xxx series (max. Core i7 6700) up to 65 W TDP
but in the Wiki for Intel Skylake series, the top CPU is i7-6700K, which is up to 95 W TDP
Can any expert confirm that i7-6700K works or does not work in H110H4-EM v2.0 please? I don't want to buy a useless CPU. And, do I have to upgrade the BIOS to use a new CPU, either an i7-6700 or an i7-6700K? My current H110H4-EM system has an i5-6400.
Also finally, I cannot find any notes about the BIOS update, what does the update achieve? Does it update CPU support or fix bugs or? Can anyone provide links with answers or BIOS notes or anything relevant.
Thanks legends.
Bericht 16 van 17
5.645 Weergaven
Bericht 16 van 17
5.645 Weergaven
hello @thisistheone
to 1. Look on the board there should be 20062009 as MSN that would be V.2
The picture shows a V.3 with the MSN 20063013
to 2. The processor is only supported up to 65 watts.
thisistheone
Bericht 17 van 17
5.503 Weergaven
Bericht 17 van 17
5.503 Weergaven
Thanks for the advice @Fishtown  I bought an i7-6700 instead to upgrade with.
16 ANTWOORDEN 16
