Akyoa E32013 Beeps 3 Times and Wont Start - No Video Ouput
2 ANTWORTEN 2
sixxxpaths
Nachricht 1 von 3
1.943 Aufrufe
Nachricht 1 von 3
1.943 Aufrufe
Hello
I changed a setting in the BIOS for the memory to run at 3000mhz instead of the default 2666mhz, I then saved the changes and proceeded to restart the PC.
Now the PC just (long) beeps 3 times and does nothing else.
I have tried clearing the CMOS using the jumper and have also removed the battery for 24 hours but it has made no difference.
I have tried different RAM sticks but same issues occur.
Is there a way to flash a fresh BIOS without having access to the BIOS or Windows?
Thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
1.928 Aufrufe
Nachricht 2 von 3
1.928 Aufrufe
Hi @sixxxpaths ,
will be challanging to install a bios version with your machine even not correctly finishing the booting process.
Maybe you can check that the memory is seated correctly and -if necessary- test it with one memory stick at a time and switch between the two plug-in locations on the board?
Cheers
sixxxpaths
Nachricht 3 von 3
1.875 Aufrufe
Nachricht 3 von 3
1.875 Aufrufe
Hi
Thanks for your reply. Unfortunately those methods did not seem to make a difference.
Not sure if there is anything else that can be done here. Probably need a new motherboard.
2 ANTWORTEN 2
