Adding extra USB 3 ports to my new Akoya
6 REPLIES 6
Lonewolf1
Message 1 of 7
Message 1 of 7
Just got an Akoya P67064 using a B460 motherboard, sorry sat on a wall outside the doctors waiting for my other half, trying to be as specific as I can!
2x usb 2.0
2x usb 3
At rear but could use more, is there any spare headers or any other way to do this internally?
And also, Hi everybody!
Cheers Jules
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 7
Message 4 of 7
Hi @Lonewolf1 ,
please find below information on your motherboard:
Main feature: CPU socket: Socket LGA 1200 (65W max.)
Chipset: INTEL FH82B460
Type: internal
Technical kernel data: ECS B460H6-EM * RAM: max. 32 GB (2 slots) * Form factor: microATX
Interfaces / Connectivity: Back panel:
* 2x USB 2.0 Type-A ports
* 2x USB 3.0 Type-A ports
* 1x DisplayPort
* 1x HDMI
* 1x LAN (RJ45) port
* 3x OFC audio jacks
Internal Connectors:
* 4 x SATA 3 ports (4x black color)
* 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
* 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
* 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
* 1 x CPU 4PIN Fan header CPU_FAN (red)
* 1 x Sys FAN 4PIN SYS_FAN (white)
* 1 x Front Audio F_AUDIO with black plastic header
* 1 x Frontside USB: Cardreader with black plastic header (one port only),
* 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
* 1 x Front_Panel header F_PANEL black plastic header
* 1 x 8PIN ATX 12V connector ATX_12V
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Processor Support
Comet Lake-S
Chipset
Intel B460
USB controller
Intel B460 chipset
2x USB 3.0 ports
2x USB 2.0 ports
Memory support
Supports max.DDR4 2666 MHz memory
2x DDR4 memory slots supporting up 32GB
Supports dual-channel mode
Audio
Realtek ALC887 HDA 8 channel Codec (6Ch rear + 2ch front function)
LAN
Realtek RTL8111H (GBit)
BIOS
AMI EFI BIOS APTIO core
SPI flash (128Mbit)
Regards,
Gehringer
6 REPLIES 6
Gehringer
Retired
Message 2 of 7
Message 2 of 7
Hi @Lonewolf1 ,
can you please provide the MSN number of your unit?
Regards,
Gehringer
Lonewolf1
Message 3 of 7
Message 3 of 7
Hi Gehringer, thanks for taking an interest👍   PC MEDION AKOYA P67064 MD35097 UK MSN: 1002 4144
Gehringer
Retired
Message 4 of 7
Message 4 of 7
Hi @Lonewolf1 ,
Type: internal
* 1x DisplayPort
* 1x HDMI
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Processor Support
Comet Lake-S
Chipset
Intel B460
USB controller
Intel B460 chipset
2x USB 3.0 ports
2x USB 2.0 ports
Memory support
Audio
LAN
BIOS
SPI flash (128Mbit)
Regards,
Gehringer
Lonewolf1
Message 5 of 7
Message 5 of 7
Looks like a no then?
Well done finding the mainboard piccie, I looked, well I thought everywhere👍
Gehringer
Retired
Message 6 of 7
Message 6 of 7
Hi @Lonewolf1 ,
it is a No, unfortunately.
At least internally.
What about USB hubs?
Regards,
Gehringer
Lonewolf1
Message 7 of 7
Message 7 of 7
Yeah, looks like it, I'll look at powered ones first of course!
6 REPLIES 6
