op 17.12.2020 18:10
op 17.12.2020 18:10
This PC comes with a 512GB SSD drive, I want to add an extra 1TB Hard disk, but there doesn't appear to be a physical mounting rack inside the PC Case. Anyone know how I can mount a drive in there?
Thanks in advance for advice anyone can offer.
op 18.12.2020 11:46
op 18.12.2020 11:46
Hi @deanf ,
please find below the details of your MB with the connectors it has and also a photo of it so you can see where to connect your HDD:
Onboard connectors:
* 4x SATA 3 ports (4x black color)
* 1x M.2 SSD (2260 and 2280) flexible standoff, SATA / PCIe NVMe mode
* 1x M.2 WIFI (2230 for WLAN only)
* 1x CPU 4PIN fan header
* 1x Sys FAN 4PIN
* 1x Front Audio F_Audio (purple)
* 1x Frontside USB F_USB1 (yellow / one port only)
* 1x Frontside USB F_USB2 (black / two ports)
* 1x USB 3.0 F_USB30 (Intel pin out / 180 degree)
* 1x Front Panel Header F_PANEL (black)
* 1x 4PIN ATX 12V Connector ATX_12V
* 1x 24PIN ATX Connector ATX_POWER
* 1x SPI debug Header SPI_Debug
Back Panel Connectors:
* 1x HDMI 2.0
* 1x DisplayPort Out
* 2x USB 2.0 (500 mA)
* 4x USB 3.2 Gen 1 (900 mA)
* 1x LAN (RJ-45)
* 1x USB 3.2 GEN2 Type-C (1.5 A)
* 1x USB 3.2 GEN2 Type-A (900 mA)
Audio Jacks:
* 1x Front Line Out (green)
* 1x Line IN (blue)
* 1x Microphone (pink)
PCI / PCIe slots:
* 1x PCIe x16 (only electrically x8 Gen3 mode)
* 2x PCIe x1
op 20.12.2020 13:57
op 20.12.2020 13:57
Hello. Do you own the akoya 32013? Could you please tell me what type of power suply has? And if you could do a picture of the interior of the computer case? Regards
op 21.12.2020 10:25
