AKOYA P67064 BSOD
5 ANTWORTEN 5
WHautot
Nachricht 1 von 6
7.026 Aufrufe
Nachricht 1 von 6
7.026 Aufrufe
AKOYA P67064 BSOD
Hello, I recently purchased one of the above for my boy but unfortunately we are seeing random BSOD which all seem to refer to memory_management or memory_corruption. I have ensured all drivers are up to date and I then resorted to a full reset but even without installing anything windows was error if again with same issue. I have ran the memtest86 and also the windows memory diagnostic tool but no errors come back. I am at a loss. I have seen some posts in other places that it could be a voltage or RAM slows issue. It’s hard to find any real specs so is anyone able to clarify these or ha e an idea of what the issue maybe?
Tags (3)
WHautot
Nachricht 6 von 6
6.974 Aufrufe
Nachricht 6 von 6
6.974 Aufrufe
The memory change appears to have resolved my issue so it must of come with faulty memory
5 ANTWORTEN 5
Gehringer
Retired
Nachricht 2 von 6
7.023 Aufrufe
Nachricht 2 von 6
7.023 Aufrufe
Hi @WHautot ,
have you tried the troubleshooting mentioned on this link here ?
Regards,
Gehringer
WHautot
Nachricht 3 von 6
7.018 Aufrufe
Nachricht 3 von 6
7.018 Aufrufe
Hello, I have done the typical BSOD troubleshooting. If I turn on driver verifier I do get the stop screens suggesting it may be a driver issue but it is not confirming what driver it may be. The windows error logs are just displaying a memory issue. But otherwise we just get random blue screens normally while gaming (not any in particular one)
One thing I have not yet tried is installing the chipset driver form the Medion downloads. I have now downloaded them however it just self extracts to a folder on C: and it does not have an installer so I am not sure where to install them? If you have any ideas would be grateful
My MSN is 10024144 if it helps
Gehringer
Retired
Nachricht 4 von 6
7.010 Aufrufe
Nachricht 4 von 6
7.010 Aufrufe
Hi @WHautot ,
if you go to device manager and select the option to update driver and then browse the PC for a driver, would you be able to indicate this newly created folder as a source of this driver?
Regards,
Gehringer
WHautot
Nachricht 5 von 6
7.007 Aufrufe
Nachricht 5 von 6
7.007 Aufrufe
Which device though does it need to be updated on, under system devices the are are a few intel entries so I am not sure which ones to apply it too.
I have also purchased some new RAM that should come today so I can rule out it being the memory hardware at fault.
WHautot
Nachricht 6 von 6
6.975 Aufrufe
Nachricht 6 von 6
6.975 Aufrufe
5 ANTWORTEN 5
