No ability to stream from pc over wifi?
1 RÉPONSE 1
Technieker1234
Message 1 sur 2
1 607 Visites
Message 1 sur 2
1 607 Visites
Hello, I just bought two P61142.
With the idea of playing music from my laptop both over the aux output to my fixed installation and over the wifi to the two medion speakers.
However, this does not work because there is no app for it on laptops.
Over bluetooth it "works", however, the walls are too thick and so the reception is very poor.
This is exactly why I chose two speakers with wifi capability, because I do have wifi everywhere.
1 RÉPONSE 1
Message 2 sur 2
1 594 Visites
Message 2 sur 2
1 594 Visites
Hi @Technieker1234 ,
to use the full functionality of the MEDION LIFE P61142 MD 433917 Wi-Fi speaker, you will have to run the MEDION Speaker App, which is (like advertised) exclusively available for mobile Android or iOS based devices.
The scenario with using the AUX output of your laptop will not work I fear in this configuration.
Just made an additional comment to your post, you left in the durch instance of the MEDION Community.
Sorry for that
1 RÉPONSE 1
