le 06.08.2021 15:16
le 06.08.2021 15:16
I recently purchased a Medion Life E66265 (MD 43147) radio/CD-player, which is a great device that I'm very happy with. However, there seems to be one small problem with it.
Two AAA batteries can be used to supply power in order to keep the time display active and to keep settings saved when the device is unplugged. These batteries will keep the device on stand-by and prevent it from being turned off completely.
However, this doesn't seem to work with my device. When I put some batteries in it and then disconnect it from the power outlet it gets completely turned off anyway, even though the batteries should have kept it on stand-by.
I've tried two different sets of batteries which both work fine in other devices. There doesn't seem to be anything visually wrong with the battery compartment either.
Any ideas?
le 17.08.2021 08:09
le 16.08.2021 10:21
le 16.08.2021 15:40
le 16.08.2021 15:40
No, all settings are lost and need to be re-entered each time the device is switched back on.
le 17.08.2021 08:09
17.08.2021 13:05 - modifié 17.08.2021 13:05
Yeah, I suspected it would probably be something like that. Well, thanks for trying to help 🙂
le 18.08.2021 08:02
20.08.2021 10:12 - modifié 20.08.2021 10:12
Well, I decided to leave it as it is since it's not really a major problem. I just placed the device somewhere else where not being able to unplug it would be less inconvenient.
