Medion Gaming Centre Hogging RAM randomly
14 ANTWORTEN 14
Sibz
Nachricht 1 von 15
15.236 Aufrufe
Nachricht 1 von 15
15.236 Aufrufe
Hi everyone,
I have an Erazer x6807 and have realised that Gaming Centre hogs up to 50% of the RAM for no reason at all.
Is there a reason for this? How can I prevent it?
Thank you,
Sibz
Gehringer
Retired
Nachricht 4 von 15
10.322 Aufrufe
Nachricht 4 von 15
10.322 Aufrufe
Hi @Sibz ,
please try reinstalling the control center.
You can download it from this link here
Regards,
Gehringer
14 ANTWORTEN 14
Gehringer
Retired
Nachricht 2 von 15
10.335 Aufrufe
Nachricht 2 von 15
10.335 Aufrufe
Hi @Sibz ,
can you please provide the MSN number of your unit?
Regards,
Gehringer
Sibz
Nachricht 3 von 15
10.330 Aufrufe
Nachricht 3 von 15
10.330 Aufrufe
Hi @Gehringer ,
My MSN number is 30026173.
Thanks,
Sibz
Gehringer
Retired
Nachricht 4 von 15
10.323 Aufrufe
Nachricht 4 von 15
10.323 Aufrufe
Hi @Sibz ,
Regards,
Gehringer
Sibz
Nachricht 5 von 15
10.309 Aufrufe
Nachricht 5 von 15
10.309 Aufrufe
@Gehringer ,
I am sorry for the late response. I have done this before and after some time the issue reappears.
I will accept this as a solution and wait to see if the issue comes up again.
Thank you.
Sibz
Nachricht 6 von 15
10.257 Aufrufe
Nachricht 6 von 15
10.257 Aufrufe
Hi @Gehringer ,
As I suspected the issue has come up again.
Please see the screenshot below.
RAM hogging Gaming CentreRAM hogging Gaming Centre
Gehringer
Retired
Nachricht 7 von 15
10.233 Aufrufe
Nachricht 7 von 15
10.233 Aufrufe
Hi @Sibz ,
this print shows that the gaming center is using only 24 MB of memory, which is not much.
Please order the list of apps running as per memory usage and check whether or not you have unnecessary apps running, even on background.
Also, please go to the startup apps menu on your W10 (start menu -> settings -> apps & features -> Startup) and review the list of apps that are defined to run when your unit starts.
That should do the trick.
Regards,
Gehringer
Sibz
Nachricht 8 von 15
10.222 Aufrufe
Nachricht 8 von 15
10.222 Aufrufe
Hi @Gehringer,
The apps were listed in order of ram usage and gaming center was using 24 GB of it. The values are in MB not KB.
Kind regards,
Arthur
Gehringer
Retired
Nachricht 9 von 15
10.200 Aufrufe
Nachricht 9 von 15
10.200 Aufrufe
Hi @Sibz ,
have you added RAM memory to your unit?
Regards,
Gehringer
Sibz
Nachricht 10 von 15
10.163 Aufrufe
Nachricht 10 von 15
10.163 Aufrufe
Hi @Gehringer,
Yes, I have 32GB of RAM.
It still happened when I had the stock 8GB RAM.
Kind regards,
14 ANTWORTEN 14
