am 07.03.2022 15:31
am 07.03.2022 15:31
Hello,
Is there a way to install an APK or any other application on MEDION LIFE X15850. I have seen that there is a store but there isn't any of the application that I'm looking for.
Or do I need to put and Android Box / Fire stick / ... to be able to add some other apps ?
Thanks
am 17.03.2022 16:18
am 17.03.2022 16:18
Hi Insinfi,
You'll need to use an external android box to access additional apps as the only ones supported come preinstalled.
Thanks.
am 20.07.2022 18:42
am 20.07.2022 18:42
So I have opted for a new generation Chromecast that work perfectly it can even replace the remote. Thanks for your help!
am 17.03.2022 16:18
am 17.03.2022 16:18
Hi Insinfi,
Thanks.
am 13.04.2022 11:07
am 13.04.2022 11:07
Yeah that is the option I will use, thanks for your help
am 19.07.2022 14:27
am 19.07.2022 14:27
Done. 🙂 Thanks
am 20.07.2022 18:42
am 20.07.2022 18:42
05.03.2025 14:36 - bearbeitet 06.03.2025 08:58
