Control Center for Medion Erazer Deputy P40
2 REPLIES 2
SantaClause
Message 1 of 3
Message 1 of 3
Hello,
I recently purchased a Medion Erazer Deputy P40 from laptops direct. I have received the laptop and its been running no issue. However I cant find the control center software for the laptop to change things like the LED or fan speeds etc, is there a link where i can download the software as it doesnt appear to be on the laptop already.
Many Thanks
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hi @SantaClause and welcome
look here: https://www.medion.com/gb/service/product-detail/30035613
bye Fishtown
2 REPLIES 2
Message 2 of 3
Message 2 of 3
bye Fishtown
Xerox
Message 3 of 3
Message 3 of 3
This error is due to the LATEST Win 11 Build update.
Issue resolved after uninstalling update
Go to settings > Windows Update > Recovery > Revert Update.
My issue is resolved after following these steps.
Additionally, switch off auto updates by by pressing Win+R > type "services.msc" > scroll down to Windows update > Disable it
Hope it helps!
2 REPLIES 2
