Control Center to Erazer Crawler E30e
8 REPLIES 8
Yuka
Message 1 of 9
Message 1 of 9
Recently my control center werent oponing than i unistalled and try to install it, but i wasnt able to find it, can someone help to find it looked like this:
Oh, and yes, i did go to the site where i just installed the files, and the control center wasnt the right. So can someone help me please?
Tags (1)
8 REPLIES 8
Yuka
Message 2 of 9
Message 2 of 9
I found the paste that have the control center to my pc and its the right. But appears this on the screen
And the application doenst appear to oppening
I apply to @Fishtown because i want to game but i need the control center to turn on the fans
Tags (1)
repoman
Message 3 of 9
Message 3 of 9
Message 4 of 9
Message 4 of 9
Olá @Yuka feliz ano novo e seja bem vindo
I'm sorry that I'm only now replying to your email.
Unfortunately I can't help you or the other users much. I'm just a user.
I don't think Medion support has a solution at the moment either.
The problem currently affects various laptops, all from Clevo with a control center that comes from Microsoft or it is related to a Windows update.
This happens every year and is not the first time.
The support will certainly already be active because it is constantly in contact with the manufacturer and will comment on it as soon as they know more.
(As usual with Medion, information only comes when you know more). so practice patiently.
Have you tried activating a restore point where everything was still running normally and then cutting off the internet connection or preventing any updates.
bye Fishtown
Yuka
Message 5 of 9
Message 5 of 9
Actually no, because i don't know how to do it.
Message 6 of 9
Message 6 of 9
Hello @Yuka ,
I understand from your answer that you haven't set a restore point manually.
but usually it is enabled by default anyway. take a look. It's explained pretty well here:
https://www.asus.com/support/faq/1018810/
Don't just watch the video but also read the text underneath.
bye Fishtown
Message 7 of 9
Message 7 of 9
@Fishtown  @Yuka
but usually it is enabled by default anyway. take a look. Iath.
bye Fishtown
Unfortunately this isn't set active by default anymore. In all my PCs the last years it was deactivated.
You first have to activate it for a  partition, and define the size of reserved space .
Go into Settings - System - About - System protection,
There you can first activate protection, then configure it, mainly only drive C: \ is important,  and then create a restore point right away.
This is for Win 10, in Win 11 it differs just a little. Or follow the above given MS FAQ for Win 11.
Bye, daddle
Message 8 of 9
Message 8 of 9
Hi @daddle
It doesn't matter whether it is deactivated for you or was already active on my laptop with Win11.
It only helps if it is already active at @Yuka , otherwise activating it later will not help with the actual problem.
bye Fishtown
Message 9 of 9
Message 9 of 9
@Fishtown
 As usual a nerving faulty post. You are wrong with your answer. Twisting the facts.
I gave general advise. I did not say it helps with the actual problem. I just stated it is not activated with all new Medion PCs I checked for within the last years
So restore points can not help Yuka, if they are not activated and configured before.
8 REPLIES 8
