Can't acces to Control Center Erazer P6605 - MD61174 - MSN 30025320
4 ANTWORTEN 4
Elgonzagana
Nachricht 1 von 5
4.556 Aufrufe
Nachricht 1 von 5
4.556 Aufrufe
Hi.
I have recently tried to access the Erazer control center on my computer, but I have not been able to either the abbreviated form (FN + ESC) or looking for it among my applications, but despite everything it comes out as an application that I can uninstall if I enter the configuration windows so I know it's still installed
How can I access my control center?
I have an erazer P6605 - MD61174 - MSN 30025320
I have also checked windows update and have no pending update.
Thank you very much for your attention and I hope someone can help me.
Nachricht 4 von 5
4.718 Aufrufe
Nachricht 4 von 5
4.718 Aufrufe
Hi @Elgonzagana , good luck
http://www1.medion.de/downloads/index.pl?op=detail&id=19783&type=treiber&lang=uk
bye Fishtown
4 ANTWORTEN 4
Gehringer
Retired
Nachricht 2 von 5
4.538 Aufrufe
Nachricht 2 von 5
4.538 Aufrufe
Hi @Elgonzagana ,
the best option would be to reinstall the control center in your machine.
During the installation you should be asked whether or not you want to overwrite the previous version.
Select yes.
Regards,
Gehringer
Elgonzagana
Nachricht 3 von 5
4.530 Aufrufe
Nachricht 3 von 5
4.530 Aufrufe
Hi.
The question is, how can I reinstall the control center, since in the partition of the hard disk I can not identify where it is, I would even dare to say that it is not there and I can assure you that my computer had control center, what's more, it appears in the section of Windows applications and features and I can even uninstall it but I can't access it. Please help me.
Thank you.
Nachricht 4 von 5
4.719 Aufrufe
Nachricht 4 von 5
4.719 Aufrufe
bye Fishtown
Elgonzagana
Nachricht 5 von 5
4.505 Aufrufe
Nachricht 5 von 5
4.505 Aufrufe
Hey!
Thanks for passing me the drivers, thanks to them I realized that I already had them in the disk partition with the name "Hotkey" and by uninstalling and reinstalling, I have the control center working perfectly again.
Thank you very much for your attention.
4 ANTWORTEN 4
