Battery No Longer charges when Laptop is on?
5 REPLIES 5
Ruthenicmike88
Message 1 of 6
Message 1 of 6
I've had this laptop almost a year when its off it charges fine but when in use the charger keeps disconnecting
5 REPLIES 5
Message 2 of 6
Message 2 of 6
Hi @Ruthenicmike88 ,
we would´ve appreciated assisting you in your case, but without knowing any specific information about your unit, it´s very difficult to provide any kind of help.
You can feeld free to get back with your issue anytime.
Cheers
Ruthenicmike88
Message 3 of 6
Message 3 of 6
Its the Erazer Gaming Notebook Crawler E10
Message 4 of 6
Message 4 of 6
Hi @Ruthenicmike88  and thank you for your reply.
This behaviour is definetely not normal and before checkng to open up a service case you could check if this tutorial delivers some helpful information:
https://community.medion.com/t5/Videoclips-Tips-Tricks-Tutorials/Tips-Device-isn-t-responding/ta-p/9...
Additional hint: To mention a community user in such a way that they will be notified when you reply, why not put an @ sign in front of their name (e.g. @Major_Tom)
Cheers
Ruthenicmike88
Message 5 of 6
Message 5 of 6
@Major_ToM My laptop wont currently hold charge when you boot it up the battery icon flashes charging then black x. Is the battery of laptop dead? Can I get replace battery/laptop?
Message 6 of 6
Message 6 of 6
the further process depends on the 8 digit article number (3002xxxx), which is placed on the lower case of the laptop und when it was bought by you.
For sure you can also feel free to get in contact with your local service center.
Cheers
5 REPLIES 5
