Game Error 8016
7 REPLIES 7
DarkKnight
Message 1 of 8
Message 1 of 8
Game Error 8016
If you come across problems running a “Securom” protected game with error “Game Error 8016” and you are running Windows 10 Operarting System with a Skylake CPU.
Please refer to the Medion driver page and update your BIOS.
This should resolve the issue.
ECS H110H4-EM (V 1.02):   http://cdn.medion.com/downloads/treiber/bioh110h4_em_w10.exe
ECS H110H4-CM2 (V 1.08): http://cdn.medion.com/downloads/treiber/bioh110h4_cm2_w10.exe
ECS BTDD-LT (V 2.21):       http://cdn.medion.com/downloads/treiber/biobtdd-lt_w10.exe
1 ACCEPTED SOLUTION
RS13
Master NL
Message 4 of 8
Message 4 of 8
Hi @mikeyduu
The P5318 i is fitted with an ECS H110H4-CM2 motherboard, so this update should fix the problem:
Kind regards,
Paul
7 REPLIES 7
mikeyduu
Message 2 of 8
Message 2 of 8
thanks for post but i dont know if any of those are for my P5318i skylate i5. getting the 8016 message 😞
mikeyduu
Message 3 of 8
Message 3 of 8
my bios is 110H4W0X.105  dated 09/08/2015 !  thanks
RS13
Master NL
Message 4 of 8
Message 4 of 8
Hi @mikeyduu
Kind regards,
Paul
mikeyduu
Message 5 of 8
Message 5 of 8
Paul, thank you very much for the link. All downloaded and flashed. Error code 8016 fixed. Can now play the problem games again, tested working is MOH 2010 :). Be safe and well m8. Mikey
RS13
Master NL
Message 6 of 8
Message 6 of 8
Hi Mikey,
Happy to help, have fun 🙂
Kind regards,
Paul
Faxe74
Message 7 of 8
Message 7 of 8
Hi,
Sorry to bring this old topic up again, but i am experiencing same problems (error 8016) om my medion P5312 (I7-6700) and I cant find a BIOS update for Win10 ?!..
Any help?
thanks in advance
Daniel
Bodgekin
Message 8 of 8
Message 8 of 8
Hi @Faxe74
There are different versions of the P5312  (P5312 J, P5312 H, P5312 G etc.), what is the MSN number for your specific system? Normally you should be able to find the correct BIOS update (if available) by searching for your MSN number on this site.
Kind regards,
Bart
7 REPLIES 7
