Wie heeft Ik ook gebruikt bij deze oplossing
113.864 Weergaven
113.864 Weergaven
busa schrieb:
@daddle
Can you dump your BIOS v009 for me?
tool: https://www.wimsbios.com/files/flashers/ami/afuwin/afuwin-3.05.04.zip
http://prntscr.com/9fsuvv
 @busa
Very nice program!
I started it and the mask gives exact same  Sizes, Core Version, Project Version,FW-ID and FW- GUID as in your Light-Box screenshot.
Just in case, please tell me/us here how to flash it back properly  Smiley Knipoog
@SmiLoDon @busa
But I don't think it's a Bios-Problem. Thousands downloads, and nobody complaint about it so far!  Only you and after you did a complete Reinstall, and before a Win 10- Upgrade! Maybe Win 10 messes something up within the Bios! But a reflash of the "new" bios 00B should help then.
Why not  recover from Recover _Partition.  Don't you have the Recover-files anymore?
So there must be some "trick" for the device-manager being able to see the second graphic-card for Installing / better said assigning the Nvidia-drivers.
That is what I asked the mods here Yesterday; an answer can earliest  be given on monday.
