46153members
951online
158119posts
MEDION has its own article numbers, which are referred to as MSNs. They are used to identify a product and enable us to offer you specific information or service for it. Only the MSN of the main item is required for this, for example the MSN of the PC.
Our products (main articles) always have an 8-digit number, which can usually be found on the type plate on the back or underside of your device.
The MD number (MEDION number) indicates which device or device series it is and what technical specifications or functions it has.
⚠️Note⚠️ If you cannot find the corresponding type plate with the MSN of your device straight away, this FAQ will help you.
