46133members
785online
158119posts
The model number is the precise designation of the respective project or product series. This number is made up of MD and a number (four- to six-digit).
This number helps both you and us to determine exactly which device respectively device series it is and what technical specifications or functions it has. It can often be found on a sticker on the packaging or directly on the appliance itself.
The MSN is decisive to show differences within a device series and precisely identifies the specific device.
⚠️Note⚠️ If you cannot find the corresponding type plate with the MD number of your device straight away, this FAQ will help you.
