FAQs about the MEDION Robot Vacuum Cleaners
  • Your robot vacuum cleaner can't find its station?
  • This may be because the station is not easily accessible or the robot does not have a clear line of sight to the charging station.
  • Your robot vacuum cleaner does not react to the virtual wall as desired?
  • This may be because the virtual wall is on a very glossy, reflective surface or the virtual wall has been positioned inappropriately.
  • Your robot vacuum cleaner does not follow the programmed cleaning schedule?
  • This may be because the Robot Vacuum Cleaner is switched off or has switched off automatically, e.g. because it has not found the charging station.
    In such a case, the programming should be done again.
Version history
Last update:
‎21.09.2023 11:12
Updated by:
Labels (1)
Contributors
