Why does the drum of my washing machine not rotate or rotate with difficulty?
Question
Answer
⚠️The transport lock must be removed before the first usage!
Unscrew the four transport securing screws with a wrench.
Take out the transport supports together with the pads from the rubber bushings and close the openings with the provided covers.
Please also note that the drum is designed for a specific load and the motor can only handle the laundry volume according to the manufacturer's specifications.
Version history
Last update:
‎20.01.2022 13:30
Updated by:
Labels (1)
Contributors
