Remote codes for P14007
2 ANTWORTEN 2
James
Nachricht 1 von 3
5.632 Aufrufe
Nachricht 1 von 3
5.632 Aufrufe
Does anyone have or know the remote code for the above tv or does it depend on the remote rather than the tv?
Bodgekin
Nachricht 2 von 3
6.568 Aufrufe
Nachricht 2 von 3
6.568 Aufrufe
Hi james,
Codes for a universal remote always depends on the remote, you usually get a list of possible codes with the remote.  If the list doesn't have any codes for a Medion TV, or the codes don't work, your best bet is to see if the remote has a searchfunction to find a working code.
Kind regards,
Bart
2 ANTWORTEN 2
Bodgekin
Nachricht 2 von 3
6.569 Aufrufe
Nachricht 2 von 3
6.569 Aufrufe
Hi james,
Kind regards,
Bart
James
Nachricht 3 von 3
5.621 Aufrufe
Nachricht 3 von 3
5.621 Aufrufe
Thanks, will try this.
2 ANTWORTEN 2
