Remote codes for P14007
2 RÉPONSES 2
James
Message 1 sur 3
5 598 Visites
Message 1 sur 3
5 598 Visites
Does anyone have or know the remote code for the above tv or does it depend on the remote rather than the tv?
1 SOLUTION APPROUVÉE
Solutions acceptées
Bodgekin
Message 2 sur 3
6 534 Visites
Message 2 sur 3
6 534 Visites
Hi james,
Codes for a universal remote always depends on the remote, you usually get a list of possible codes with the remote.  If the list doesn't have any codes for a Medion TV, or the codes don't work, your best bet is to see if the remote has a searchfunction to find a working code.
Kind regards,
Bart
2 RÉPONSES 2
Bodgekin
Message 2 sur 3
6 535 Visites
Message 2 sur 3
6 535 Visites
Hi james,
Kind regards,
Bart
James
Message 3 sur 3
5 587 Visites
Message 3 sur 3
5 587 Visites
Thanks, will try this.
2 RÉPONSES 2
