Remote codes for P14007
2 ANTWOORDEN 2
James
Bericht 1 van 3
5.595 Weergaven
Bericht 1 van 3
5.595 Weergaven
Does anyone have or know the remote code for the above tv or does it depend on the remote rather than the tv?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bodgekin
Bericht 2 van 3
6.531 Weergaven
Bericht 2 van 3
6.531 Weergaven
Hi james,
Codes for a universal remote always depends on the remote, you usually get a list of possible codes with the remote.  If the list doesn't have any codes for a Medion TV, or the codes don't work, your best bet is to see if the remote has a searchfunction to find a working code.
Kind regards,
Bart
2 ANTWOORDEN 2
Bodgekin
Bericht 2 van 3
6.532 Weergaven
Bericht 2 van 3
6.532 Weergaven
Hi james,
Kind regards,
Bart
James
Bericht 3 van 3
5.584 Weergaven
Bericht 3 van 3
5.584 Weergaven
Thanks, will try this.
2 ANTWOORDEN 2
