op 25.10.2023 12:04
op 25.10.2023 12:04
I have a MEDION X14339 (MD30059) Android TV.
When I switch on the TV from standby, the volume is always muted, even when it wasn't when viewing the last channel before standby.
Can this be solved with the next update please?
op 03.01.2024 08:06
op 03.01.2024 08:06
Hi @XPloRR ,
couldyou please give us an information,if this behaviour has been present since the first start, or did it occur somewhen inbetween? Are any further devices connected to the TV, which could cause the effect and did you already perform a factory reset, to check if the reported behaviour can still be observed then?
Cheers
op 19.02.2024 11:18
op 19.02.2024 11:18
The problem existed from the beginning (clean install)
op 21.02.2024 14:16
op 21.02.2024 14:16
Hi @XPloRR .
thanks for your feedback. Could you report us the software version from your devices menue to internally check for an update from our side?
Cheers
