System recovery disc
11 RÉPONSES 11
Cg
Message 1 sur 12
25 935 Visites
Message 1 sur 12
25 935 Visites
Hi,
While I was completing a clean up of my laptop the lead came out and when I turned it back on it wouldn't boot, I found a Windows and system back up discs so put these in to re boot my laptop but once it has installed to my horror I had installed a system from a completely different laptop, which has also left me missing drivers that allows me to connect to Internet,,, so my question is how and where would I get a system recovery disc to reinstall my medion akoya system back on. And would this work ? Many thanks.
11 RÉPONSES 11
Cg
Message 11 sur 12
5 269 Visites
Message 11 sur 12
5 269 Visites
no , dont know too much about them,
however i have now found and downloaded and installed the ethernet and wireless drivers and it is now working
thanks for youe help.
Message 12 sur 12
5 262 Visites
Message 12 sur 12
5 262 Visites
@Cg
Glad for you and great that it works. Which Medion-drivers could you use? The wifi I guess, and did the Medion Win 7 ethernet-driver one works with Vista as well?
Just please mark the thread as solved by checking the checkbox under my post which helped, and if you like you can say "thanks" by checking the green-button with the stars under my post(s).
11 RÉPONSES 11
