Re: Wiederherstellungspaket für P10356
21 ANTWORTEN 21
Eck001
Nachricht 1 von 22
9.059 Aufrufe
Nachricht 1 von 22
9.059 Aufrufe
ich hab mir das Wiederherstellungspaket gezogen und versucht einzuspielen.
Leider bekomme ich nun auf meinem Tablet nurnoch das LIFETAB Logo angezeigt und er bootet nicht mehr weiter.
Beim flashen kommen auch ein paar Fehler, hauptsächlich was die oem commands betrifft.
Hier mal die Log vom Flashvorgang:
*** Intel flash process stage 1 ***
1) Power off the device.
2) Press and hold [Power]+[VolUp]+[VolDn] for 5 seconds.
3) Connect device to PC via USB.
< waiting for any device >
Sending 'osloader' (279 KB)                        OKAY [  0.016s]
Writing 'osloader'                                 OKAY [  0.003s]
Finished. Total time: 0.034s
Sending 'boot.img' (13394 KB)                      OKAY [  0.531s]
Booting                                            OKAY [  0.000s]
Finished. Total time: 0.550s
Gewartet wird  7 Sekunden. Weiter mit beliebiger Taste...
*** Intel flash process stage 2 ***
                                                   FAILED (remote: 'unknown OEM command')
fastboot: error: Command failed
                                                   (bootloader) CMD 'wipe /ESP'...
(bootloader) erasing volume "/ESP", size=67108864...
(bootloader) wrote ret 3108864, count 17,  "/dev/block/by-name/ESP"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/ESP"
OKAY [  1.553s]
Finished. Total time: 1.561s
                                                   (bootloader) CMD 'wipe /reserved'...
(bootloader) erasing volume "/reserved", size=67108864...
(bootloader) wrote ret 3108864, count 17,  "/dev/block/by-name/reserved"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/reserved
OKAY [  1.571s]
Finished. Total time: 1.577s
                                                   (bootloader) Start partitioning
OKAY [  0.109s]
Finished. Total time: 0.114s
Sending 'gpt' (1 KB)                               OKAY [  0.066s]
Writing 'gpt'                                      FAILED (remote: 'flash_cmds error!
******** Did you mean to fastboot format this ext4 partition?
Erasing 'factory'                                  OKAY [  0.109s]
Finished. Total time: 0.216s
Erasing 'system'                                   OKAY [  0.425s]
Finished. Total time: 0.522s
mke2fs 1.44.4 (18-Aug-2018)
Creating filesystem with 262144 4k blocks and 65536 inodes
Filesystem UUID: 2423ec38-f652-11e9-b453-5374ca118c1e
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
Sending 'cache' (340 KB)                           OKAY [  0.077s]
Writing 'cache'                                    OKAY [  0.103s]
Finished. Total time: 0.497s
Creating filesystem with 4096 4k blocks and 4096 inodes
Creating journal (1024 blocks): done
Sending 'config' (48 KB)                           OKAY [  0.068s]
Writing 'config'                                   OKAY [  0.096s]
Finished. Total time: 0.459s
Creating filesystem with 8192 4k blocks and 8192 inodes
Sending 'logs' (52 KB)                             OKAY [  0.070s]
Writing 'logs'                                     OKAY [  0.096s]
Finished. Total time: 0.465s
                                                   (bootloader) Stop partitioning
OKAY [  0.090s]
Finished. Total time: 0.096s
Sending 'ESP' (65536 KB)                           OKAY [  1.626s]
Writing 'ESP'                                      OKAY [  1.401s]
Finished. Total time: 3.219s
Sending 'fastboot' (13394 KB)                      OKAY [  0.387s]
Writing 'fastboot'                                 OKAY [  0.376s]
Finished. Total time: 0.945s
Erasing 'keystore'                                 FAILED (remote: 'unable to format')
Sending 'factory' (48 KB)                          OKAY [  0.067s]
Writing 'factory'                                  OKAY [  0.120s]
Finished. Total time: 0.493s
Creating filesystem with 524288 4k blocks and 131072 inodes
Filesystem UUID: 28077f4a-f652-11e9-a9de-dfa97c91c119
        32768, 98304, 163840, 229376, 294912
Creating journal (16384 blocks): done
Sending 'system' (604 KB)                          OKAY [  0.083s]
Writing 'system'                                   OKAY [  0.108s]
Finished. Total time: 0.510s
Creating filesystem with 6751227 4k blocks and 1689120 inodes
Filesystem UUID: 286370d4-f652-11e9-8f7e-7fcf03f7d078
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000
Creating journal (32768 blocks): done
Sending 'data' (4272 KB)                           OKAY [  0.169s]
Writing 'data'                                     OKAY [  0.185s]
Finished. Total time: 0.726s
Filesystem UUID: 28de0bdc-f652-11e9-99dd-dd198a74726a
Writing 'cache'                                    OKAY [  0.106s]
fastboot: error: cannot load 'esp.zip': No such file or directory
Sending 'fastboot' (13394 KB)                      OKAY [  0.376s]
Writing 'fastboot'                                 OKAY [  0.390s]
Finished. Total time: 0.921s
Sending 'boot' (10226 KB)                          OKAY [  0.308s]
Writing 'boot'                                     OKAY [  0.325s]
Finished. Total time: 0.784s
Sending 'recovery' (10892 KB)                      OKAY [  0.315s]
Writing 'recovery'                                 OKAY [  0.325s]
Finished. Total time: 0.795s
Sending sparse 'system' 1/9 (194848 KB)            OKAY [  4.894s]
Writing 'system'                                   OKAY [  4.063s]
Sending sparse 'system' 2/9 (202286 KB)            OKAY [  5.067s]
Writing 'system'                                   OKAY [  4.299s]
Sending sparse 'system' 3/9 (204775 KB)            OKAY [  5.320s]
Writing 'system'                                   OKAY [  4.439s]
Sending sparse 'system' 4/9 (204746 KB)            OKAY [  5.210s]
Writing 'system'                                   OKAY [  4.591s]
Sending sparse 'system' 5/9 (200541 KB)            OKAY [  5.045s]
Writing 'system'                                   OKAY [  4.105s]
Sending sparse 'system' 6/9 (195662 KB)            OKAY [  5.192s]
Writing 'system'                                   OKAY [  4.065s]
Sending sparse 'system' 7/9 (199541 KB)            OKAY [  5.014s]
Writing 'system'                                   OKAY [  4.244s]
Sending sparse 'system' 8/9 (183646 KB)            OKAY [  4.572s]
Writing 'system'                                   OKAY [  3.962s]
Sending sparse 'system' 9/9 (82060 KB)             OKAY [  2.133s]
Writing 'system'                                   OKAY [  1.756s]
Finished. Total time: 81.260s
Sending 'capsule' (5624 KB)                        OKAY [  0.215s]
Writing 'capsule'                                  OKAY [  0.295s]
Finished. Total time: 0.665s
Resuming boot                                      OKAY [  0.048s]
Finished. Total time: 0.055s
*** Finished.                   ***
Wäre super wenn mir jemmand helfen könnte.
21 ANTWORTEN 21
Anonymous
None
Nachricht 21 von 22
481 Aufrufe
Nachricht 21 von 22
481 Aufrufe
Guten Abend auch,
vielen Dank für Deine Zeit, auch wenn ich nicht den erhofften Tipp bekommen habe, warum das ADB Interface
abschaltet wenn das Tablet in droidboot.img lädt...
Mit Verlaub, ich habe alle Varianten (als Admin oder auch nicht, alle möglichen Konstellationen der ADB, etc.) durch-
probiert... und ich kann auch Bedienungsanleitungen lesen.
Ich werde der Sache schon noch auf den Grund kommen, muss ich mich eben mit der vorhanden shell beschäftigen...
oder ich finde jemanden, der tiefer in der Software und Strukturen steckt... vielleicht ist auch ein älterer PC mit Dos
oder Win7 die Lösung, meiner jetzt ist ein i9 mit Win11pro... oder ich versuch's mal mit Linux...
Nochmal, nichts für ungut und vielen Dank für Deine Zeit.
btw, die diversen .img innerhalb von "P1035X-5.0-factory-20151022_v1.4" zusammen, sind das "ROM"...
die flash Anweisungen in der .bat heben Sperren auf, löschen, Formatieren (gpt und nach einer vorgegebenen
Partitionstabelle, richten da saubere Partitionen ein und flashen die einzelnen .img)...
So, ich verabschiede mich hiermit aus der Community, das Tablet habe ich in meinem jugendlichen Leichtsinn
vor 10 Jahren gekauft, weil ich dachte, Intel Atom plus Tastatur macht es leichter etwas anderes aufzuspielen
als Android (Medion ist ja nicht eben berühmt für updates)... wenn 5.x überholt sind (war's ja auch relativ schnell)...
das Teil lag jetzt 7, 8 Jahre im Schrank... unbenutzt... hab's nur gelegentlich benutzt...
Schönen Abend noch allerseits (falls jemand mitliest),
bollland
VG, bollland
Nachricht 22 von 22
461 Aufrufe
Nachricht 22 von 22
461 Aufrufe
@Anonymous
Edit:
Mit Verlaub, ich habe alle Varianten (als Admin oder auch nicht, alle möglichen Konstellationen der ADB, ...
.) durchprobiert...
Was soll das denn? Und bitte was heißt   "als Admin oder auch nicht, alle möglichen Konstellationen der ADB ...durchprobiert)  ???
Welche ADB Konstellationen.. Dein Wissen kratzt nur an der Oberfläche. Und ich bin schon 50 cm tief. 😁
Und es gibt nicht den einen Tipp, und ich weiß auch nicht was Cyanogen oder Lineage bei deinen fruchtlosen Versuchen mit dem
 Tablet angerichtet hat!
Und zu den Bedienungsanleitungen, es steht nirgends dass man die neueren Android Tools nehmen soll. Die Frage ist die der Kompatibilität.
Edit Ende
Win 7 statt Win 11 zu nehmen schrieb ich im ersten oder zweiten  Post, damit ginge es besser.  Win 11 passt oft nicht zu älteren Routinen.
 Ich  habe bisher etliche User anleiten und  mit ihnen erfolgreich ihre Tablets wiederherstellen können. Bei Befolgen der Standards in den  Anleitungen.
In dieser Wiederherstellung.zip fehlte leider die Windows Fastboot.exe und die zugehörigen Apis.
Aber du hast recht, ich stecke nicht in den Tiefen der Android und/oder Linux Programmierung drin.
Ich weiß nur eines, es hat immer dann geklappt, wenn man sich genau an die Anleitungen (plus den empfohlenen Ergänzungen) hielt. Mit den Dateien aus der damaligen Zeit. Selbst der "Author" hat es damit geschafft.
Er hat die von mir empfohlene fastboot.exe und die Apis ins Flashverzeichnis kopiert, dann  funktionierte die Wiederherstellung.
Die neueren Apis und auch fastboot.exe unterscheiden sich von den damals genutzten älteren Versionen. Win 11 Android 12 oder 13 unterscheiden sich deutlich vom damaligem Android 5.x.
Habe einen  bit zu bit Vergleich gemacht. Aber jeder so  wie er meint es besser zu wissen.
Und ob du die Hinweise im meinem letzten Post. " Alles auf Original, dazu die fehlenden Dateien ins Flashverzeichnis kopieren", steht bei deinen wenig  zustimmenden  Antworten auf meine Hinweise noch nicht fest.
Sonst hast du immer Bilder vom Flashvorgang aus der cmd kopiert.
Jetzt keines? Etwas merkwürdig.
Vielleicht hat es damit ja sogar geklappt, was  du hier jetzt nicht mehr zugeben könntest.. Habe ich auch schon öfters erlebt. Ein plötzlich abrupter Abbruch, mit ein paar versteckten Kritiken, gibt mir zu denken.
Ich frage mich nur wieso du so beharrlich auf deinen Weg beharrst, statt einmal den Windows-Rechner von allen fremden von dir vorgenommenen Änderungen zu befreien (dazu gehören auch deine neueren Android Tools und die gesetzten Umgehungsvariablen.)
Das Wiederherstellungspaket verlangt das Alles nicht.
Ehrlich, das ist mir ja so was von neu!
Wieso meinst du mir das erklären zu müssen? Meine Hinweise im Verlauf zeigen dass ich da sehr wohl verstanden habe. Dient das dem eigene Selbstwertgefühl?
Es war die Frage nach dem Bootloader, ob der Osloader dem sonst so genannten "Bootloader" entspricht.  Zumindest die Wortwahl ist etwas irritierend.  Andererseits wird  die efilinux-user.efi in die Partition.osloader geflasht mit nachfolgendem Flashen der boot.img. Was ich auch  bereits sagte.
Wenn du nur Ausschnitte aus der CMD wie im letzten Bild postest, und man den Pfad und die eingegebenen Befehle nicht sieht, kann man schlecht wissen, und raten gar nicht, was genau geschehen ist.
Auch lässt sich nicht erkennen ob du die cmd  aus dem Verzeichnis heraus durch Aufruf der flash.bat gestartet, oder erst eine Admin cmd gestartet hast. 2. Weg ist manchmal besser, wenn man dann den Pfad aufs Flashverzeichnis setzt.
Fehlen die apis , wird  im Aufruf der flash.bat aus dem Verzeichnis heraus (ohne vorheriges Öffnen  eines cmd Fensters) nur die ersten drei Zeilen in der sich dann öffnenden CMD gezeigt. Mit einer Fehlermeldung, dass der Code weiter nicht ausgeführt werden kann (da die Apis fehlen, die fastboot.exe benötigt.)
Wenn du willst, schicke mir dein Tablet zu, dann flashe ich das, natürlich umsonst. Ich habe noch meinen Win 7- Rechner  aus der damaligen Zeit fertig konfiguriert fürs Flashen der damaligen Tabs (habe etliche davon)
Wo Wohnst du ? Weiteres per PN.
Gruß, daddle
21 ANTWORTEN 21
