am 24.10.2019 13:42
am 24.10.2019 13:42
ich hab mir das Wiederherstellungspaket gezogen und versucht einzuspielen.
Leider bekomme ich nun auf meinem Tablet nurnoch das LIFETAB Logo angezeigt und er bootet nicht mehr weiter.
Beim flashen kommen auch ein paar Fehler, hauptsächlich was die oem commands betrifft.
Hier mal die Log vom Flashvorgang:
*** Intel flash process stage 1 ***
1) Power off the device.
2) Press and hold [Power]+[VolUp]+[VolDn] for 5 seconds.
3) Connect device to PC via USB.
< waiting for any device >
Sending 'osloader' (279 KB) OKAY [ 0.016s]
Writing 'osloader' OKAY [ 0.003s]
Finished. Total time: 0.034s
Sending 'boot.img' (13394 KB) OKAY [ 0.531s]
Booting OKAY [ 0.000s]
Finished. Total time: 0.550s
Gewartet wird 7 Sekunden. Weiter mit beliebiger Taste...
*** Intel flash process stage 2 ***
FAILED (remote: 'unknown OEM command')
fastboot: error: Command failed
(bootloader) CMD 'wipe /ESP'...
(bootloader) erasing volume "/ESP", size=67108864...
(bootloader) wrote ret 3108864, count 17, "/dev/block/by-name/ESP"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/ESP"
OKAY [ 1.553s]
Finished. Total time: 1.561s
(bootloader) CMD 'wipe /reserved'...
(bootloader) erasing volume "/reserved", size=67108864...
(bootloader) wrote ret 3108864, count 17, "/dev/block/by-name/reserved"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/reserved
OKAY [ 1.571s]
Finished. Total time: 1.577s
(bootloader) Start partitioning
OKAY [ 0.109s]
Finished. Total time: 0.114s
Sending 'gpt' (1 KB) OKAY [ 0.066s]
Writing 'gpt' FAILED (remote: 'flash_cmds error!
******** Did you mean to fastboot format this ext4 partition?
Erasing 'factory' OKAY [ 0.109s]
Finished. Total time: 0.216s
Erasing 'system' OKAY [ 0.425s]
Finished. Total time: 0.522s
mke2fs 1.44.4 (18-Aug-2018)
Creating filesystem with 262144 4k blocks and 65536 inodes
Filesystem UUID: 2423ec38-f652-11e9-b453-5374ca118c1e
Superblock backups stored on blocks:
32768, 98304, 163840, 229376
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
Sending 'cache' (340 KB) OKAY [ 0.077s]
Writing 'cache' OKAY [ 0.103s]
Finished. Total time: 0.497s
Creating filesystem with 4096 4k blocks and 4096 inodes
Creating journal (1024 blocks): done
Sending 'config' (48 KB) OKAY [ 0.068s]
Writing 'config' OKAY [ 0.096s]
Finished. Total time: 0.459s
Creating filesystem with 8192 4k blocks and 8192 inodes
Sending 'logs' (52 KB) OKAY [ 0.070s]
Writing 'logs' OKAY [ 0.096s]
Finished. Total time: 0.465s
(bootloader) Stop partitioning
OKAY [ 0.090s]
Finished. Total time: 0.096s
Sending 'ESP' (65536 KB) OKAY [ 1.626s]
Writing 'ESP' OKAY [ 1.401s]
Finished. Total time: 3.219s
Sending 'fastboot' (13394 KB) OKAY [ 0.387s]
Writing 'fastboot' OKAY [ 0.376s]
Finished. Total time: 0.945s
Erasing 'keystore' FAILED (remote: 'unable to format')
Sending 'factory' (48 KB) OKAY [ 0.067s]
Writing 'factory' OKAY [ 0.120s]
Finished. Total time: 0.493s
Creating filesystem with 524288 4k blocks and 131072 inodes
Filesystem UUID: 28077f4a-f652-11e9-a9de-dfa97c91c119
32768, 98304, 163840, 229376, 294912
Creating journal (16384 blocks): done
Sending 'system' (604 KB) OKAY [ 0.083s]
Writing 'system' OKAY [ 0.108s]
Finished. Total time: 0.510s
Creating filesystem with 6751227 4k blocks and 1689120 inodes
Filesystem UUID: 286370d4-f652-11e9-8f7e-7fcf03f7d078
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000
Creating journal (32768 blocks): done
Sending 'data' (4272 KB) OKAY [ 0.169s]
Writing 'data' OKAY [ 0.185s]
Finished. Total time: 0.726s
Filesystem UUID: 28de0bdc-f652-11e9-99dd-dd198a74726a
Writing 'cache' OKAY [ 0.106s]
fastboot: error: cannot load 'esp.zip': No such file or directory
Sending 'fastboot' (13394 KB) OKAY [ 0.376s]
Writing 'fastboot' OKAY [ 0.390s]
Finished. Total time: 0.921s
Sending 'boot' (10226 KB) OKAY [ 0.308s]
Writing 'boot' OKAY [ 0.325s]
Finished. Total time: 0.784s
Sending 'recovery' (10892 KB) OKAY [ 0.315s]
Writing 'recovery' OKAY [ 0.325s]
Finished. Total time: 0.795s
Sending sparse 'system' 1/9 (194848 KB) OKAY [ 4.894s]
Writing 'system' OKAY [ 4.063s]
Sending sparse 'system' 2/9 (202286 KB) OKAY [ 5.067s]
Writing 'system' OKAY [ 4.299s]
Sending sparse 'system' 3/9 (204775 KB) OKAY [ 5.320s]
Writing 'system' OKAY [ 4.439s]
Sending sparse 'system' 4/9 (204746 KB) OKAY [ 5.210s]
Writing 'system' OKAY [ 4.591s]
Sending sparse 'system' 5/9 (200541 KB) OKAY [ 5.045s]
Writing 'system' OKAY [ 4.105s]
Sending sparse 'system' 6/9 (195662 KB) OKAY [ 5.192s]
Writing 'system' OKAY [ 4.065s]
Sending sparse 'system' 7/9 (199541 KB) OKAY [ 5.014s]
Writing 'system' OKAY [ 4.244s]
Sending sparse 'system' 8/9 (183646 KB) OKAY [ 4.572s]
Writing 'system' OKAY [ 3.962s]
Sending sparse 'system' 9/9 (82060 KB) OKAY [ 2.133s]
Writing 'system' OKAY [ 1.756s]
Finished. Total time: 81.260s
Sending 'capsule' (5624 KB) OKAY [ 0.215s]
Writing 'capsule' OKAY [ 0.295s]
Finished. Total time: 0.665s
Resuming boot OKAY [ 0.048s]
Finished. Total time: 0.055s
*** Finished. ***
***********************************Wäre super wenn mir jemmand helfen könnte.
24.10.2025 15:14 - bearbeitet 25.10.2025 14:50
@Anonymous
Hallo Bolland,
Ich finde dein Verhalten etwas merkwürdig. Du hast diesen Beitrag vor vier Tagen geschrieben und mich dann dringlich per privater E-Mail gebeten (mit einem etwas merkwürdigen, selbstgefälligen Hinweis auf meine Geduld, die ich vor einigen Jahren mit einem anderen begriffsstutzigen Nutzer gezeigt hatte),
um mich moralisch zu verpflichten, dir mit dem über 10 Jahre alten Tablet zu helfen.
Zitat:
@Anonymous schrieb:an @daddle per PN:
Ich suche jemand, ...der mir betreffend Wiederherstellung (OS) des P10356 weiterhelfen kann... ich hoffe das könnte mit Ihnen/Dir klappen, genug Geduld für Manuel30 war anno dazumal zumindest vorhanden... ..
Das Tab ist über 10 Jahre alt, damals und, auch vor 6 Jahren war ich noch in der Materie mitten drin......
Aber da ich am "Social Helper Syndrom" leide, auf das du abstellst
habe ich dir sehr ausführlich geantwortet und dir Tipps zu den möglichen Ursachen gegeben, soweit ich das ohne das Gerät vor mir zu haben sagen kann.
Aber es kommt keine Reaktion von dir; ich hätte zumindest eine kurze Antwort erwartet....
Die Erfolgs- oder auch Misserfolgsmeldung und daraus evtl. entstehende weitere Fragen könnten dann ja später in weiteren Post erfragt werden.
Edit:
Ich habe noch zwei weitere mögliche Fehlerquellen gefunden, aber es macht keinen Sinn wenn ich mich hier theoretisch ausbreite, aber die Antworten zur Anwendung der Korrekturen nicht kommen.
am 26.10.2025 13:40
am 26.10.2025 13:40
Hallo daddle,
tut mir leid, dass ich nicht sofort und unverzüglich... ich habe familiäre Verpflichtungen (weiblich 12, 10)... ich bedanke mich in aller Form
für die sehr flotte Rückantwort und ich bin froh einen Ansprechpartner zu haben (wenn ich das so bezeichnen darf)... selbstgefällig war der
Verweis auf den begriffsstutzigen Zeitgenossen nicht, ich fand' dessen Äußerungen nur reichlich daneben... bekommt Hilfestellung und be-
schwert sich noch darüber...
Ich hoffe mein Kniefall für die 4 Tage war jetzt tief genug... ich habe versucht jetzt alle Info noch mal im Detail zusammenzufassen und ich
schicke das per PM, in der Hoffnung das Sozialhelfersyndrom schamlos ausnutzen zu können...
VG, bollland
26.10.2025 15:25 - bearbeitet 26.10.2025 16:49
@Anonymous
Ein Kniefall ist überhaupt nicht nötig, und erwarte ich auch gar nicht. Bin nur neugierig ob es evtl. an den genannten Punkten liegt
Nun zum Vorgehen. Lade dir bitte das Wiederherstellungspaket erneut runter.. Welches hast du genommen? Das für Android Version 5.0 (Lollipop) ? Du musst das nehmen, mit dem das Tablet damals gekauft wurde. Updaten kann man später noch
Und verändere nichts in der flash.bat; du schriebst du hättest versucht da etwas zu ändern. Die Parameterangebe
"-force" war in der Form übrigens falsch.
Im Paket fehlt die Windows fastboot,exe; wenn du dir diese nicht woanders her geholt und in das Flash-Verzeichnis kopiert hast, kommst du über Intel Stage 1 nicht hinaus.
Ich lade sie dir hoch, einschließlich der fraglichen fehlenden Dlls und der Treiber Datei IntelAndroidDrvSetup 1.10.exe.
Die IntelAndroidDrvSetup.exe ermöglicht die sichere Verbindung Tablet zum PC. Aber danke an die vorherige Deaktivierung der Signaturprüfung.
Wolltest du noch eine PN schreiben mt der Beantwortung der Fragen? Ich warte gerne... 😉
Gruß, daddle
Edit:
Damit müsste es gehen. Entpacken, und die Dateien in das ebenfalls entpackte Wiederherstellungs-Verzeichnis P1035X-5.0-factory kopieren.
--> https://drive.google.com/file/d/1N-5W7ZlHzph1SFsIxaBlCZp4zk34tP52/view?usp=drive_link
26.10.2025 17:40 - bearbeitet 26.10.2025 21:31
@Anonymous
@Anonymous schrieb:Wiederherstellungspaket ist das Original von der Medion homepage entsprechend Label des Tablets... ergänzt mit den adb und der esp.zip (aber soweit geht's ja gar nicht...)...
Adb und esp.zip ( gehören nicht dazu) ADB.. xxx ist wenn ein Treiber Wo hast du das her? Ist nicht im Paket) und muss in Windows installiert sein. Und es gjbt das Image esp.img für die Partition ESP.
was ich probiert habe (Amateur) ist, Auszüge aus der batch Datei allein laufen zu lassen,
zum löschen, formatieren, etc.
Das kann so nicht funktionieren.
Die Verbindung zum Tablet scheint zu stehen, allerdings gibt es nur Fehlermeldungen....
Kein Wunder, denn fastboot.exe fehlt, dann kann auch nicht geflasht werden.
Jetzt bin ich mit meinem bisschen Latein am Ende...
Im Lollipop Paket ist keine esp.zip enthalten, muss auch nicht, nur das esp.img (Image).
Der Befehl in der flash.bat lautet entsprechend: { fastboot.exe flash ESP esp.img }
Das bedeutet Fastboot.exe flasht das esp.img in die Partition ESP .
Jetzt halte dich bitte wörtlich an die Installationsanleitung, installiere zuerst die IntelAndroidDrvSetup1.10.exe in Windows (aus Google Drive) unter vorherigen Ausschaltung der Signaturüberprüfung, in Windows 10.
Dann gehe ins entpackte Verzeichnis der Wiederherstellungsdateien in denen du die Dateien fastboot exe und die Dlls kopierst,
Das Tablett ausmachen, SD card und USB Kabel abmachen;
Die flash.bat starten
Danach wie beschrieben das Tablet mit der Tastenkombination Power und Vol + und Vol - gleichzeitig für ca 10 Sek. drücken, anschalten dann sollte es in den Flashmodius (DnX ) kommen
dann das Tablet per USB Kabel verbinden, und
der Wiederherstellungs-Vorgang startet automatisch und dauert einige Minuten.
Das Gerät startet mehrfach automatisch neu.
Gruß, daddle
Edit:
Link zu Google Drive ergänzt.
am 26.10.2025 22:15
am 26.10.2025 22:15
Schönen guten Abend,
Meine Hardware:
MD99632 Model:P10356
MSN 30019779
EAN 29061341 Y./C.: 12/10/15
Benutzter Medion link zum download:
https://www.medion.com/de/service/product-detail/30019779
P1035X-5.0-factory-20151022_v1.4.zip
FlashIntelBYT-DE.pdf
Medion Lifetab P10356 (MD 99632) Tablet.pdf
Installierte Intel Treiber (abgeschaltete Signaturprüfung):
IntelAndroidDrvSetup1.10.0.zip
Inhalt Wiederherstellungspaket von Medion:
Ergänzt um folgende Dateien aus dem aktuellen SDK Paket / Android: sdk-repo-windows-platform-tools.zip
Damit das auch klar ist, ADB ist Systemweit installiert, d.h. bei den Umgebungvariablen in den erweiterten Systemeinstellungen eingetragen.
Die Dateien habe ich nur nochmal hierhin kopiert, weil in den alten Threads die ich gefunden habe online, immer wieder darauf hingewiesen
worden ist, das diese im Medion Paket fehlen... also gut, tut auch keinem was... platform-tools-latest-windows.zip
Jetzt zu der flash.bat - siehe Zeile 85 (rot markiert):
@Echo off
set ERASE=true
set BIOS=true
set FORCE=true
set IMAGE_MODEL=LIFETAB
:loop
if "%1" == "" goto main
if "%1" == "--update" set ERASE=false& shift & goto loop
if "%1" == "--nobios" set BIOS=false& shift & goto loop
if "%1" == "--no-force" set FORCE=false& shift & goto loop
echo Unknown option "%1".
goto done
:main
echo.
echo ***********************************
echo *** Intel flash process stage 1 ***
echo.
echo 1) Power off the device.
echo 2) Press and hold [Power]+[VolUp]+[VolDn] for 5 seconds.
echo 3) Connect device to PC via USB.
echo.
fastboot.exe flash osloader efilinux-user.efi
fastboot.exe boot droidboot.img
timeout 10
echo.
echo *** Intel flash process stage 2 ***
echo.
if "%FORCE%" == "true" goto erase
fastboot.exe reboot-bootloader
echo.
echo Reboot bootloader, sleeping for 10 seconds...
echo.
timeout 10
fastboot.exe getvar product-model > tmp.log 2>&1
for /f "delims=" %%i in ('findstr product-model tmp.log') do call :Foo "%%i"
goto End
:erase
if "%ERASE%" == "false" goto flash
fastboot.exe oem enable_oem_unlock
fastboot.exe oem unlock
fastboot.exe oem wipe ESP
fastboot.exe oem wipe reserved
fastboot.exe oem start_partitioning
fastboot.exe flash gpt partition.tbl
fastboot.exe erase factory
fastboot.exe erase system
fastboot.exe format cache
fastboot.exe format config
fastboot.exe format logs
fastboot.exe oem stop_partitioning
fastboot.exe flash fastboot droidboot.img
fastboot.exe erase keystore
fastboot.exe format factory
fastboot.exe format system
fastboot.exe oem verified
fastboot.exe format data
:flash
fastboot.exe flash esp_update esp.zip
fastboot.exe flash boot boot.img
fastboot.exe flash recovery recovery.img
fastboot.exe -S 200M flash system system.img
if "%BIOS%" == "false" goto boot
fastboot.exe flash capsule capsule.bin
:boot
fastboot.exe continue
echo.
echo *** Finished. ***
echo.
:done
Deswegen habe ich die esp.zip aus dem Wiederherstellungspaket des S1035x kopiert und in das
Paket für das P10356 eingefügt. Ich kann es auch wieder rausschmeißen (hab ich jetzt auch) , falls
die "Wiederherstellung" erst mal bis dahin laufen sollte...
So, nun zu dem P10356 - da ist nix mehr drauf, keine Recovery, keine Formatierung, keine Partitionen;
Einzig ADB/fastboot (laut/leise plus power) funktioniert, beim Tablet Start meldet sich nur noch die Shell;
Das sog. „EFI Boot Fix“- Paket hab' ich leider erfolglos online gesucht, die alten links für downloads leben
nicht mehr...
So, batch wird gestartet am PC (original, ohne meine "Ergänzungen", d.h. ohne die ADB.exe und die dlls, ohne fastboot.exe und ohne die
esp.zip - die fastboot braucht es auch nicht, da systemweit Umgebungsvariable !!!):
Am Tablet power & laut/leise:
So, jetzt angesteckt...
auf Tablet - Seite:
zuerst:
nach ein paar Sekunden:
Auf der PC Seite:
Sobald das Tablet in die "Fastboot CMD waiting" lädt, ist die Verbindung unterbrochen und keine Seite tut was...
Zur Info, mit Gparted unter Knoppix (live USB) nachgeguckt, läuft 30sec. - dann friert's ein:
VG & angenehmen Abend noch,
bollland
am 27.10.2025 02:37
am 27.10.2025 02:37
@Anonymous
Endlich ein paar harte Fakten zu deinem P10365, vor allem die MSN Nummer 30019779.
Aber es ändert sich eigentlich nichts:
Im entpacktem Download P1035X_20151022_V1.4_with_Shellscript\ sind folgende Dateien:
flash.bat
flash.sh
fastboot
flash-EraseFactory.xml
installer.cmd
system.img
droidboot.img
recovery.img
boot.img
esp.img
efilinux-user.efi
flash_L_user.xml
flash_L_user_no-BIOS.xml
capsule.bin
ifwi.bin
build.prop
partition.tbl
Keine esp.zip, die ausführbare Datei fastboot.exe fehlt wie schon früher gesagt,
Die flash.bat enthält folgende Befehle: (Siehe Zeile 75 grün, un d85
@echo off
set ERASE=true
set BIOS=true
set FORCE=true
:loop
goto done
:main
echo.
echo.
echo.
timeout 10
echo.
echo.
echo.
echo.
timeout 10
goto End
:erase
fastboot.exe flash ESP esp.img Diese Datei ist vorhanden und wird geflasht
:flash
(Diese esp.zip ist im Download nicht vorhanden. Dann wird sie nicht geflasht, **
:boot
echo.
echo.
:done
** Jetzt frage ich mich, woher hast du die "esp.zip", die du entfernt hast ??
@Anonymous schrieb:Deswegen habe ich die esp.zip aus dem Wiederherstellungspaket des S1035x kopiert und in das Paket für das P10356 eingefügt. I
Das dürfte wohl nicht passen!
Siehe auch Post 1 von Eck001 im flashverlauf. Darin steht Error "eine esp.zip ist nicht vorhanden". Wird m.E. nach nicht benötigt.
Zu deinen sonstigen Bilder kann ich nichts sagen, da sie noch nicht freigegeben sind. Erst morgen.
Der Bootloader wird doch im Anfang als OS-loader in der flash.bat geflasht --> efilinux-user.efi, und dann wird Droidboot gebootet.
Wird eigentlich das Tab im Geräte -Manager angezeigt als Android device? Ich meine nicht den MTP Eintrag.
Vielleicht solltest du doch die fastboot.exe ins Wiederherstellungsverzeichnis kopieren,, ist sicherer, , und klappt das mit der Umgebungsvariable beim flashen nicht.
Bis morgen, daddle
27.10.2025 13:07 - bearbeitet 27.10.2025 20:54
@Anonymous
Edit: Was passiert wenn du in der EFi Shell gelandet bist und Exit Return eingibst?
@Anonymous schrieb:.......
So, batch wird gestartet am PC (original, ohne meine "Ergänzungen", d.h. ohne die ADB.exe und die dlls, ohne fastboot.exe und ohne die esp.zip - die fastboot braucht es auch nicht, da systemweit Umgebungsvariable !!!):
Doch ich denke schon! Sollte im Verzeichnis drin sein. Und fastboot.exe benötigt beim Aufruf die AdbWinApi.dll und die AdbWinUsbApi.dll.
So, jetzt angesteckt... auf Tablet - Seite:
zuerst:
Diese Efilinux error -> "No devices support filesystems" und "fs:Init failed, DnX mode ?" machen mir etwas Kopfschmerzen, auch wenn es nach kurzer Zeit die "normale" DnX Maske kommt mit <Waiting for fastboot command >
Nach ein paar Sekunden:
Alle Fehlermeldungen beziehen sich auf die fastboot.exe.
Vermutlich funktionieren die Umgebungsvariablen beim Flashvorgang auf Android nicht, so dass deine schöne fastboot.exe Umgebungsvariable beim Flashen aussetzt und nicht gefunden wird.
Du hast es noch nie ausprobiert mit dem originalem Wiederherstellungsverzeichnis um die fastboot.exe, die AdbWinApi.dll und AdbWinUsbApi.dll ergänzt das Flashen durchzuführen
Außerdem ist die Frage, ob die neuere fastboot.exe kompatibel zu den älteren Androidversionen ist. Denke aber scon.
Warum macht du es nicht wortwörtlich so wie es im Script steht. Also dazu die Fastboot.exe, die AdbWinApi.dll und die AdbWinUsb.dll, die ich dir in Google Drive hochgeladen habe, ins Wiederherstellungsverzeichnis zu kopieren. Und damit zu flashen.
Aber die falsche esp.zip vom anderem Tablet darf nicht drin sein.
Wenn du das zumindest nicht probierst wäre weiteres Supporten nicht mehr sinnvoll
V.G., daddle
am 27.10.2025 20:23
am 27.10.2025 20:23
N'Abend,
--> korrekt!
--> auch korrekt, ist aber vorläufig völlig einerlei!
--> Mit oder ohne, Ergebnis ist immer das Gleiche... warten wir die Freigabe der Bilder ab bitte,
vielleicht kommt dann mehr Licht ins Dunkel...
--> Dann lande ich im Bios(?)-Menü, also Seite mit den 6 Auswahlboxen (Continue, Boot Manager, Device Management, Boot from file, Secure boot option, SCU)
Du hast es noch nie ausprobiert mit dem originalem Wiederherstellungsverzeichnis um die fastboot.exe und Korrektur: um die AdbWinApi.dll und die AdbWinUsbApi.dll ergänzt.
--> Inkorrekt !!! Es gibt seit es Android gibt verschiedene Versionen der Android Platform tools (ADB plus Dienstprogramme). Ich habe die runtergeladene Version von Medion und ein zwei andere Versionen bis hin zur
aktuellen Version durchprobiert, mit den entsprechenden files innerhalb des "Wiederherstellungspaketes" und auch ohne... das Resultat ist immer das Gleiche...
Ich bin zwar kein Profi, aber bis zu einem gewissen Grad kann ich mir schon helfen...
Warum macht du es nicht wortwörtlich so wie es im Script steht. Also die Fastboot.exe, die ich dir in Google Drive hochgeladen habe, ins Wiederherstellungsverzeichnis kopieren, Korrektur: und die AdbWinApi.dll und AdbWinUsb.dll.
--> Nicht nur wörtlich, sondern buchstäblich... Deine Dateien vom Google-Drive werden von meinem Virenscanner angemeckert... aber warum soll "Deine" adb, dll & fastboot von 2015/2016 was anderes sein als "Meine"...
Das sind öffentlich zugängliche Dienstprogramme.... der Inhalt der flash.bat für das S1036x ist absolut identisch mit der flash.bat vom P10356... die fastboot.exe und AdbWinApi.dll / AdbWinUsb.dll sind vom 24.03. bzw. 02.03.2016
Eine batch ist nicht anderes als eine Stapelverarbeitung von Anweisungen, aber das muss ich ja nicht erklären...
--> Genau hier ist das Problem... AD device aktiv bis der Droidboot started, dann inaktiv und nix mehr geht weiter... egal in welcher Form ich das o.g. benutzt / genutzt habe, egal welche Versionen oder Konstellationen.
Schönen Abend noch und bis morgen.
27.10.2025 21:15 - bearbeitet 28.10.2025 09:14
@Anonymous
@Anonymous schrieb:Vielleicht solltest du doch die fastboot.exe ins Wiederherstellungsverzeichnis kopieren,, ist sicherer, und klappt das mit der Fattboot.exe Umgebungsvariable beim Flashen nicht.
--> Mit oder ohne, Ergebnis ist immer das Gleiche... warten wir die Freigabe der Bilder ab bitte, vielleicht kommt dann mehr Licht ins Dunkel...
Bisher hattest du das noch nicht gemacht bzw mitgeteilt, dass du es mit dieser fastboot.exe und den Dlls von mir im Google Drive hochgeladen auch versucht hattest.
Das P10365 ist zeitnah zu dem S10346 rausgekommen, das sind die OS LL5.02 und LL 5.1 bei dir fast identisch.
Dann ist die Wahrscheinlichkeit grösser, dass die Dateien passen
Dass der Virenscanner beim Download der Apis meckert ist normal, kann man drüber hinweg gehen. Keine Gefahr!
Es nutzt aber nichts nicht flexibel zu sein. Einfach ausprobieren
Welche Bilder meinst du, es sind in deinem Post keine vorhanden. Und meine sind ja nur die auf den bereits von dir kommentierten Text bezogen, da ist nichts Neues zu sehen.
@Anonymous schrieb:Edit: Was passiert wenn du in der EFi Shell gelandet bist und Exit Return eingibst?
Hast du die Optionen durchprobiert, vor allem Continue?
Du kannst ja in der Shell exit auf dem Tablet mit einer externen Tastatur eingeben.
Was ich nicht genau weiß ist ob der osloader gleich dem Bootloader zu setzen ist.
Es könnte sein dass mit deinen Experimenten mit Cyanogen und LineageOS der eventuell vor dem osloader kommende Bootloader gelöscht wurde. Dann geht nichts mehr.
Dann bräuchtest du ein komplettes ROM, inclusive dem Bootloader.
Gruß, daddle
Edit : Typo
27.10.2025 21:44 - bearbeitet 28.10.2025 14:07
@Anonymous
Heureka! Ich glaube ich habs.
Ich sehe gerade deine Pfadangabe im cmd Fenster ist falsch. Die Command als Admin aufrufen. Dann den Pfad des Wiederherstellungsverzeichnisses in der Kopfzeile einstellen. Du hast von C:\Windows\system32\cmd.exe aus die flash.bat aufgerufen
Du solltest aber zuerst per cd Befehle den Pfad des Flashverzeichnis einstellen .
Die flash.bat und die fastboot.exe suchen die zu flashenden Images und Dateien im Verzeichnis, in dem die flash.bat steht. Daher muss aus diesem Verzeichnis heraus die flash.bat aufgerufen werden. Auch wenn fastboot.exe in den Umgebungsvariablen steht, die muss ja auf das Flashverzeichnis zugreifen können um die entsprechenden Dateien zu flashen.
Also fastboot.exe und die Api Dll's ins Verzeichnis kopieren. Das command fenster als Admin aufrufen, dann zum entpacktem Verzeichnis navigieren.
Per cd Befehle:
[ In der Kopfzeile steht: Microsoft Windows [Version xxxxx ] Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten.
c:\Windows\system32\cmd.exe C:\Windows\system32>cd \ C:\> C:\>cd Verzeichnis-Name der entpackten zip [= P1035X-5.0-factory-20151022_v1.4;je nachdem wie benannt ] C:\>P1035X-5.0-factory-20151022_v1.4> C:\>P1035X-5.0-factory-20151022_v1.4> flash.bat
Das geht wie oben angegeben, falls dein entpacktes Flash Verzeichnis auf C:\ ist.
Du hast es P1036X genannt? Steht bei dir unter D:\Downloads\Medion Tablets\P1035X>. Das ist das entpackte Wiederherstellungsverzeichnis ?
Wegen dem kürzerem Pfad und Namen verschiebe das entpackte Wiederherstellungsverzeichnis einfach nach C:\.
Dann mit cd Befehlen zu dem Unterverzeichnis P10365X mit dem Inhalt der entpackten Wiederherstellungszip navigieren. Da dann die flash.bat ohne einen Parameter aufrufen.
(Zu dem Zeitpunkt dieses ersten Bildes von dir fehlten aber im Flash-Verzeichnis noch die AdbWinApi.dll, AdbWinUsbApi.dll und die fastbooot.exe aus meiner Google Drive Ablage)
Mach es einfach, egal ob es in den Umgebungsvaríablen steht; denn die Api.dll's hast du nicht dort eingetragen, oder? Genauso muss der Zugriff auf die im Flashverzeichnis liegenden zu flashenden Dateien gegeben sein, was nur geht, wenn in dem Cmd Fenster Header der Pfad des Flashverzeichnisses steht.
Es kommen meistens mehrere Faktoren zusammen wenn das Flashen nicht funktioniert.
Mehr kann ich nicht tun. Wenn du dich nicht wenigstens einmal genau an die Installationsanweisung plus die Ergänzungen hältst, sehe ich keine weitere Möglichkeit dich zu unterstützen.
Gruß, daddle
