EFI Boot Fix - doesn't help
18 ANTWORTEN 18
ZAJDAN
Nachricht 1 von 19
16.894 Aufrufe
Nachricht 1 von 19
16.894 Aufrufe
Hello,
I have the known problem where a tablet boots into efi shell. So I try to use EFI Boot Fix .
Flash drive is formated as fat32, EFI Bott Fix files are placed on the flash drive. I connect the FlashDrive via OTG to tablet and powerOn the tablet.
The result is, that tablet doesn't start Android OS and again do the same problem. I captured a screenshot from the tablet durring the fixing process.
Thanks for any hints
Tags (2)
18 ANTWORTEN 18
ZAJDAN
Nachricht 11 von 19
8.462 Aufrufe
Nachricht 11 von 19
8.462 Aufrufe
ZAJDAN
Nachricht 12 von 19
8.461 Aufrufe
Nachricht 12 von 19
8.461 Aufrufe
@daddle
I am not sure if I understand You correctly (german language I translate via translator), but Yes I use OTG reduction with three different USB sticks(512MB, 6GB, 8GB) all formated as FAT
do You think will be good to try use USB HUB?
tablet->OTG->USB HUB->USB Stick
Nachricht 13 von 19
8.445 Aufrufe
Nachricht 13 von 19
8.445 Aufrufe
No, not seriously. Did you use an USB-hub flashing the recovery-package?
ZAJDAN
Nachricht 14 von 19
8.441 Aufrufe
Nachricht 14 von 19
8.441 Aufrufe
@daddle
Not, everytime it was connected via OTG reduction, about the hub it was just idea if it will helps.
Nachricht 15 von 19
8.437 Aufrufe
Nachricht 15 von 19
8.437 Aufrufe
@ZAJDAN
Here in your flash failure-protocol it says "error":
error: cannot load '/efilinux-.efi': No such file or directory
I think the error text should be:
error: cannot load '/efilinux-user.efi': No such file or directory
That is maybe the reason für your bootorder-error; the efilinux-user.efi file was never found nor flashed, because the flash.sh looks instead for the  "/efilinux-user .efi" for the "/efilinux- .efi" ?
The flash.sh says:
 "./fastboot flash osloader $OUT/efilinux-$TARGET_BUILD_VARIANT.efi"
Did you mess around with the " $OUT/efilinux-$TARGET_BUILD_VARIANT.efi" line, and gave this the possible wrong error-text? Or is the efilinux-path wrongly written??
(Although later on the esp.zip is flashed, which also contains the identical files in  Boot/ bootx64.efi and in /Intel/efilinux.efi; but do not know if bin the same position.
May be @TheDoctor could check this
ZAJDAN
Nachricht 16 von 19
8.430 Aufrufe
Nachricht 16 von 19
8.430 Aufrufe
@daddle
if You will read mentioned thread completely, You will see, that I solved this problem about load necessary files.
in the script is something wrong with variable $OUT
I could also try windows version 😞
Nachricht 17 von 19
8.425 Aufrufe
Nachricht 17 von 19
8.425 Aufrufe
Off course I read. Otherwise I couldn't have noticed the missing "user" in error-text:
"error: cannot load '/efilinux-.efi': No such file or directory"
The  $TARGET_BUILD_VARIANT isn't replaced by "user" in error. Should it be?
Like I said in the beginning, I do not know much about Linux or Android.
May be by replacing standard $OUT with your long path-name (too long?) you made an error or typo?
And yes, reflashing the recovery-package in Windows you should try; but for safety reason make a new download before.
ZAJDAN
Nachricht 18 von 19
8.420 Aufrufe
Nachricht 18 von 19
8.420 Aufrufe
when I replace the $OUT everywhere where the variable is , with my absolute path /home/zajdan/Downloads/medion-p7332/
the mentioned files are loaded without error
ZAJDAN
Nachricht 19 von 19
8.393 Aufrufe
Nachricht 19 von 19
8.393 Aufrufe
I tried recovery package also from windows, but during process stage 2 each step ends with status FAILED
https://community.medion.com/t5/Tablet/ANDROID-RECOVERY-PAKET/m-p/42058/highlight/false#M8809
18 ANTWORTEN 18
