Problem with memory at phone B5531
6 REPLIES 6
mklasinc
Message 1 of 7
Message 1 of 7
I have Medion phone B5531 (Android 5.1.1, 32 GB memory). Memory check shows 23,4 GB used memory by applications and 7,6 GB for system. When checking all apps and summarize their occupancy they occupy all together only 5 GB. I deleted data from gmail and the used memory for gmail shrinked from 7 GB to only 92 MB but the total used memory still shows 23,4 GB. I don't know hot to convince telephone that it has more available memory than it shows. It remains for work only 390 MB and I cannot make even any necessary update. I don't have saved any videos and only few photos and very small number of apps installed. Plese, help!
6 REPLIES 6
Message 2 of 7
Message 2 of 7
Hello @mklasinc and welcome
I can't find any data on your cell phone at all.
can you please give the MSN number once, thank you
bye Fishtown
mklasinc
Message 3 of 7
Message 3 of 7
What do you mean by "I can't find any data on your cell phone at all."?
Message 4 of 7
Message 4 of 7
Hi @mklasinc
I can't find any information on your b5531 phone, including on google so please give your MSN number.
bye Fishtown
mklasinc
Message 5 of 7
Message 5 of 7
What is MSN number?
joseph69
Message 6 of 7
Message 6 of 7
bye Fishtown
Hello,
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue. Bumped into your thread. Thanks for creating it. Looking forward for solution.
Message 7 of 7
Message 7 of 7
Hi  @joseph69
do you have a MSN number for a b5531?
Bye Fishtown
6 REPLIES 6
