Akoya X5344 G/C276 drivers.
1 REPLY 1
User5344
Message 1 of 2
Message 1 of 2
Hi, is there a list to know every driver that can be installed for this machine? I use this PC for gaming, so i would want to have every proper driver. Or you think that with the optional updates of Windows Update the drivers are all up-to date and correct? I also did sometime a go the optional updates which included the BIOS, but who knows if all the drivers are really up-to date, since for example, if you update the graphic driver with Windows if good it's one year old, while if you download from AMD's website it's old two months... Thank's.
1 REPLY 1
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Hi @User5344 ,
there may be a delay between the launch of a new driver and its availability via Windows update.
There are third-parties software that monitor your drivers and warn you if you need any updates.
Regards,
Gehringer
1 REPLY 1
