Akoya E14034 periodically crashes
1 REPLY 1
andyonthemearns
Message 1 of 2
Message 1 of 2
Akoya E14304 periodically crashes, refuses to reboot and then perhaps 10/20 mins later boots up. The only problem I've come across is Windows Security issue. Device Security shows a yellow triangle and Memory Integrity "IS OFF" your device may be vulnerable. On trying to switch Memory Integrity to"ON" it takes me to "Core Isolation" and to review incompatible drivers viz IT9135BDA.sys and PxHlpa64.sys . This is all gobbledegook to me and any help on how to fix this would be most welcome.
Thanks in advance.
1 REPLY 1
Message 2 of 2
Message 2 of 2
@andyonthemearns
I, like you, don't know  what all this about is - it's just all " gobbledegook" 😐
But you could try to do  a inplace repair with a Windows Iso.
Download  the same Windows version and build (or newer ), and start the setup.exe inside Window..
Success, daddle
Edit  Typo
1 REPLY 1
