Wifi
3 REPLIES 3
Spike105
Message 1 of 4
Message 1 of 4
Wifi
Hi I have a medion 32’’’ TV (MD 31944)
but I am struggling to connect it to the internet !!!!!
I have tried turning the router off on back on while the network was disabled
can anyone point me in the right direction please ??
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @Spike105 ,
network connection should be a straight-forward procedure.
You can either perform a first time installation (TV reset in some models) and then configure your internet connection as part of the procedure or you can access the Network menu (menu->settings->network) and configure your network type.
Are you receiving any particular error message?
Regards,
Gehringer
Spike105
Message 3 of 4
Message 3 of 4
Hi I’ve set it up one ok but I’ve changed internet provider and it won’t connect!!
it just says unsuccessful on the screen ??
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi,
this error message is normally due to a wrong password.
Please make sure that you have the proper password on sight and then select the option to show password before confirming what you've typed,  so you can be sure everything is ok.
Regards,
Gehringer
3 REPLIES 3
