Windows
3 REPLIES 3
Alexis93
Message 1 of 4
Message 1 of 4
Windows
Hello all
I received as a gift Medion Akoya e2888t md 61050 . This notebook have some problem with operation sistem . How i can save windows to reinstall ? Or i can install another sistem ?
Thank you !
Tags (1)
1 ACCEPTED SOLUTION
Message 2 of 4
Message 2 of 4
@Alexis93
Your PC is a E2228T, not an E2888T. The MSN for to find spare parts and Drivers quickly is: 30023301.
You have to install Windows anew, making use of Microsofts "MediaCreationTool", to create an USB-Installation- Stick.
Afterwards you have to install the Driver-Package which you will find on the ServicePortal, (using MSN)
regards, daddle
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@Alexis93
regards, daddle
HarrisonRan
Message 3 of 4
Message 3 of 4
No, obviously you have to install Windows. That will be better and the best solution here.
writemyessay.onl
Message 4 of 4
Message 4 of 4
@HarrisonRan
Quite late your answer to be worshipped. I wrote this in the forelast post on March 12th 2018  already.
Now we have December 7th 2020!  😉
3 REPLIES 3
