WiFi adaptor driver update
3 RÉPONSES 3
Raybt123
Message 1 sur 4
6 180 Visites
Message 1 sur 4
6 180 Visites
MD 8828 Akoya desktop unable to use WiFi re driver update download required, info help required.
Ry Parkin
1 SOLUTION APPROUVÉE
Solutions acceptées
FrankFitch
Message 3 sur 4
5 942 Visites
Message 3 sur 4
5 942 Visites
Rolling back the driver is another way to make Wi-Fi work stably, or at least just work :). There are no guarantees that it will help, but if nothing else helps, then it's worth a try. All in the same device manager, right-click on the same Wi-Fi adapter. And select Properties from the menu.
Go to the Driver tab and click the Roll Back button. It may be that the rollback button is not active. There is nothing to do here, which means there is no older driver in the system. A message will appear stating that rolling back to an older version of the driver may downgrade functionality buyessays, and so on Click Yes. We reboot the laptop and check how Wi-Fi works.
3 RÉPONSES 3
Gehringer
Retired
Message 2 sur 4
6 142 Visites
Message 2 sur 4
6 142 Visites
Hi @Raybt123 and welcome to the FORUM!
Can you please let us know the MSN number of your product?
It is an 8-digits number that you can find printed on a label underneath it. It usually starts by 100, 300 or 500.
Also, why do you say you can't you update it? How are you trying to do so? Did you get any error message?
Regards,
Gehringer
FrankFitch
Message 3 sur 4
5 943 Visites
Message 3 sur 4
5 943 Visites
Raybt123
Message 4 sur 4
5 937 Visites
Message 4 sur 4
5 937 Visites
Dear Frank, Thank you for your help my friend. I hope you are keeping well during this pandemic. be nice to get to know you.
Ray Parkin
3 RÉPONSES 3
