Medion Akoya P6627
2 RÉPONSES 2
san8155
Message 1 sur 3
3 544 Visites
Message 1 sur 3
3 544 Visites
Medion Akoya P6627
Hi,
We have a Medion Akoya P6627 upgraded with a SSD drive. Recently the fan doesn't appear to work and the computer overheats and shuts down. Is this due to a faulty fan or could it be that the incorrect BIOS is installed. Any comments and advise appreciated.  Thanks J
2 RÉPONSES 2
Gehringer
Retired
Message 2 sur 3
3 539 Visites
Message 2 sur 3
3 539 Visites
Hi @san8155 and welcome to the FORUM!
It can actually be both so you may need to test a few things.
Your model has drivers listed in here that you can download and install.
Also, try using the device manager to check if your firmware is updated. You can find instructions on how to do so here
Lastly, try updating Windows to its latest version to get all the drivers updates available.
Regards,
Gehringer
Croen
Message 3 sur 3
3 529 Visites
Message 3 sur 3
3 529 Visites
Hello,
I had the same issue with overheating. I've a Medion Akoya P6659. You need to make sure all the latest drivers are installed. Also, the problem disappeared when I replaced my Crucial 8GB Kit (2 x 4GB) DDR3L-1600 SODIMM with the Kingston’s KC600 SSD.
customwritingcompany.com
2 RÉPONSES 2
