MEDION LIFE X15061 (MD 31541)
5 ANTWOORDEN 5
ar1884
Bericht 1 van 6
3.011 Weergaven
Bericht 1 van 6
3.011 Weergaven
Hi,
My TV MEDION LIFE X15061 (MD 31541) did an automatic software update and now it won't start anymore. The blue light keeps on flashing more than 24h after the initial update. Is there a way to get the old version back (without starting the TV since it does not)? Or can I try to redo the update via a USB stick?
Thank you very much in advance,
5 ANTWOORDEN 5
Bericht 2 van 6
3.004 Weergaven
Bericht 2 van 6
3.004 Weergaven
Hi @ar1884 and welcome
Try this if your device is in the list.
X15061/ MD31541/ MSN ??
https://community.medion.com/t5/kb/en/ta-p/131092
good luck, Fishtown
ar1884
Bericht 3 van 6
2.973 Weergaven
Bericht 3 van 6
2.973 Weergaven
Thank you for your reply. My TV is indeed in the list, but I tried to update it with a usb stick using that softare, but it did not work...
Daniel
Bericht 4 van 6
2.952 Weergaven
Bericht 4 van 6
2.952 Weergaven
Hello @ar1884
I'm about to send you a software for your TV via private message. After that, the TV should work again.
VG,
Daniel
Slli
Participant
Bericht 5 van 6
1.937 Weergaven
Bericht 5 van 6
1.937 Weergaven
Is it possible that I receive this software as well? I have a Medion MD30630, blue blinking light…. @Daniel
Daniel
Bericht 6 van 6
1.929 Weergaven
Bericht 6 van 6
1.929 Weergaven
Hello @Slli
yes it is possible. I will send you the same message.
VG,
Daniel
5 ANTWOORDEN 5
