notebook S3409 not switching on
2 REPLIES 2
bebbindf
Message 1 of 3
Message 1 of 3
Hi
My S3409, which has worked perfectly for a number of years, this morning is not powering on.
I was using it and my keyboard stopped working, or at least I couldn't type on any application, I decided to hibernate the notebook and restart it to kick the keyboard back into action, I did this by pressing the power button as I normally do. However once it had hibernated it will not power back up, neither with battery or mains. No lights come on whatsoever.
I have looked on some pages which suggest removing the mains cable and the battery, holding the power button for 30 seconds. replacing the battery and/or power but that has not helped.
Anyone any ideas please?
Thanks
Dave
1 ACCEPTED SOLUTION
bebbindf
Message 3 of 3
Message 3 of 3
Hi
Many thanks for the response, but no, the charger was not the issue, but was related! The LED card for the charger had burnt out, one I removed it off the motherboard all worked fine.
Regards
Dave
Tags (1)
2 REPLIES 2
mats749
Message 2 of 3
Message 2 of 3
Hi @bebbindf
Welcome to the community!
Have you checked the charger to ensure that its working correctly?
Thanks
Mats749
bebbindf
Message 3 of 3
Message 3 of 3
Hi
Regards
Dave
Tags (1)
2 REPLIES 2
