erazer deputy p25 msn number sticker gone
2 REPLIES 2
magnea
Message 1 of 3
Message 1 of 3
so yeah exactly what the title says the sticker is gone but i do have my serial number on the back still is there ANY way to find the msn number somewhere on my laptop itself??
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
@magnea
Hi.
How can this  be?
The sticker actually is very sticky! It's  on the bottom of the case
The MSN number also is printed on the Box it came with. Or you can try msinfo32; on the fist page
--> System-SKU you might find at the end an 8-digit number.
Or go to the Servcie page, and enter "  Deputy P25 ". There comes a list with about  30 models, which are basically the same. MAy be you reckonize the Suffix UK or whatever country  model you ordered
---> https://www.medion.com/de/service/topic/medion-products?msnCheck=Deputy%20P25
Cheers, daddle
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@magnea
Hi.
How can this  be?
Cheers, daddle
magnea
Message 3 of 3
Message 3 of 3
yess thank you i saw that last seccond thx ❤️
2 REPLIES 2
