04.06.2020 09:45
04.06.2020 09:45
Hi,
I'm trying to use the USB-C displayport with a multiport adaptor to connect the laptop to either a VGA monitor or an HDMI television with no success.
Does anyone know of an adaptor that is definitely compatible for both HDMI and VGA for this laptop?
thanks, Jim
04.06.2020 10:37
04.06.2020 10:37
As you say , it is a display-port. So you need an adaptor USB-C to Display-Port. That's all.
If behind this you can add other adptors to convert to HDM or VGA, I do not know.
But first you have to extract the display-port signal from the C-port.
04.06.2020 11:07
Thanks @daddle.
There are loads of adaptors available that go straight from the "USB C Displayport" to female HDMI and/or VGA, but compatibility varies. Just trying to find out if anyone connects this model laptop to a monitor or projector and which adaptor they use. I can't be the first person to do this.
Regards, Jim
