VGA / HDMI adaptor for Akoya S4403
2 RÉPONSES 2
JimH
Message 1 sur 3
1 514 Visites
Message 1 sur 3
1 514 Visites
Hi,
I'm trying to use the USB-C displayport with a multiport adaptor to connect the laptop to either a VGA monitor or an HDMI television with no success.
Does anyone know of an adaptor that is definitely compatible for both HDMI and VGA for this laptop?
thanks, Jim
2 RÉPONSES 2
Message 2 sur 3
1 512 Visites
Message 2 sur 3
1 512 Visites
@JimH
As you say , it is a display-port. So you need an adaptor  USB-C to Display-Port. That's all.
If behind this you can add other adptors to convert to HDM or VGA, I do not know.
But first you have to extract the display-port signal from the C-port.
JimH
Message 3 sur 3
1 508 Visites
Message 3 sur 3
1 508 Visites
Thanks @daddle.
There are loads of adaptors available that go straight from the "USB C Displayport" to female HDMI and/or VGA, but compatibility varies.  Just trying to find out if anyone connects this model laptop to a monitor or projector and which adaptor they use.  I can't be the first person to do this.
Regards, Jim
2 RÉPONSES 2
