Some keys Medion Akoya E6421 not working. Front cover won't open.
1 ANTWOORD 1
Spartacus
Bericht 1 van 2
3.049 Weergaven
Bericht 1 van 2
3.049 Weergaven
Hi,
Some keys on my Medion Akoya E6421 are not working.
I have removed the battery and pressed the start button for 60s, as well as reinstall the keyboard drivers. This does not solve the problem.
A youtube tutorial on a similar issue adviced to clean the ribbon of your keyboard.
Because the keyboard of my laptop is under the front cover of my laptop, I first had to remove the front cover which did not go, as the cover couldn't be removed where the DVD player was.
Are there alternatives that i can try and does anyone know if there are any videos or guides on how to open the cover of the Medion Akoya E6421.
Thanks
1 ANTWOORD 1
aryaalin
Bericht 2 van 2
2.145 Weergaven
Bericht 2 van 2
2.145 Weergaven
hi
https://www.youtube.com/watch?v=xURycCM5ccg
Hope it will help you
Regards
1 ANTWOORD 1
